Thread: How to lower PH without lowering TA ?
    Jul 2016
    College Station
    21
    Hi,
    I have a new plaster pool about month old. First couple of weeks used lots of acid to lower the TA and finally got it where wanted. Took about 7 gallons of acid.
    Anyhow I find myself having to add acid now just because of PH. PH creeps up to 7.7-7.8 range and every couple of days I find myself adding pint or 2 of acid. I don't mind doing this but am very worried I'll end up dropping the TA.
    So how to drop the PH without dropping TA ?
    FC 5.0
    CC 0
    TC 5.0
    PH 7.7
    CH 170
    TA 90
    CYA 40
    25K gal, plaster, 1.0 jandy spa pump, Two 1.5 gallon pool pumps, DE Filter, Glass Tile sheer descent and spa.
    Jun 2015
    Glendale, AZ
    156
    Re: How to lower PH without lowering TA ?
    Likely your pH will keeping rising for a while, adding acid will lower TA. Until your plaster fully cures, you will have to keep an eye on both pH and the TA. Finding a sweet spot on the TA will help.
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    It is OK to let your TA drop down as low as 60, even 50 if you PH remains stable. If not then you can raise TA with baking soda without raising PH much.
    More handy info about chems here, Pool School - Recommended Pool Chemicals
    Jul 2015
    Central Valley CA
    1,109
    With our new pool walmart baking soda was a staple for the first 6 month or so. I was going through 4 pounds every 3 to 4 weeks.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
