Thread: Lubrication of stenner tubes?
    Dec 2013
    San Diego, CA
    18
    Question Lubrication of stenner tubes?
    The stenner tube in my Pentair Intelliph acid injector developed a hole after just 4 months of use and I'm wondering why it failed prematurely since the previous tube lasted 16 months. I have been periodically lubricating the stenner tube with WD40 brand silicon spray and I'm wondering if that could have degraded the tubing. The Intelliph owners manual recommends cleaning the pump rollers with a non-citrus cleaner, but there's no mention of lubrication. Should I avoid lubricating the tube from now on?
    21,000 ga plaster pool with infinity edge.
    Pentair Easy Touch controller, IntelliChlor, IntellipH.
    Pentair 3hp VS pool pump, Pentair 1.5hp single speed pump for infinity edge.
    Rooftop solar.
    May 2016
    Troy IL
    476
    Re: Lubrication of stenner tubes?
    I've never heard of anyone lubing their Stenner tubes.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Apr 2016
    Rockville MD
    43
    I would just make sure the rollers spin freely, no lube.
    20x35 in-ground oval. Wet Edge Luna Quartz finish. Hayes Super Pump with AO Smith V-Green 165 VS motor. Polaris 380. Enersol solar heating with automatic controller. Automated chlorination with Stenner pump.
    22,543
    That WD-40 whie being silicone probably has some propellants that attack the santoprene tubing, and that probably contributed to the shortened life.
