Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Need help with pool test using TF100
    May 2015
    Austin, TX
    118
    I did some tests using the TF100 kit today
    K1000 test
    Cl 1ppm
    Ph 8.2
    Chlorine drop test - no chlorine, fc 0, cc 0
    TA 180
    My tf100 was purchased in july 2015, during the year i did not use it because i had a pool guy , i recently took over managing my own pool. Is the tf100 kit results valid, since its a year old?
    This is a 15000 gallon salt water pool. The SWG shows 2800 and i have it running in the super chlorinate position , generating light is ON.
    Since Chlorine was low, and i need to use the pool in few hours. I added two one pound bags of chlor brite, that product from leslies.
    Please advise what I should do next.
    15K gal, IG (I think its Vinyl not sure), 2 HP WhisperFlo pump, 60 sqft Pentair DE filter, SWG Hayward Aqua rite controller with t-cell-15, Aqualink RS6, Jandy Spa side 4-button, Polaris 280, 400K Pentair Minimax NT Heater Propane, test kit TF100
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: Need help with pool test using TF100
    Can you post a complete run of tests:
    FC
    CC
    pH
    TA
    CH
    CYA
    Where did the test kit get stored?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Time to do a little reading in Pool School.
    Start here, ABCs of Pool Water Chemistry
    Then here, Pool School - Getting Started
    May 2015
    Austin, TX
    118
    Quote Originally Posted by YippeeSkippy View Post
    FC
    CC
    pH
    TA
    CH
    CYA
    I think i left out the CYA and CH test. The test kit was stored inside my home , in a closet.
    I am in Austin , 100 degree days past week and my pool gets lots of sunlight
    May 2015
    Austin, TX
    118
    Quote Originally Posted by pooldv View Post
    I did browse through pool school. Is there a page there that tells me what specific actions to take after conducting tests with the tf100 ?
    DFW, TX
    24,450
    For a saltwater pool you want this water chemistry, Pool School - Water Balance for SWGs
    If those didn't cover it, there is more here, TFPC for Beginners
    May 2015
    Austin, TX
    118
    FC
    CC
    pH
    TA
    CH
    CYA
    FC 15
    CC 1
    Ph 8.2
    TA 150
    CH 250
    CYA 20
    Jan 2012
    7,264
    Quote Originally Posted by Sal512 View Post
    FC 15 Too high to swim, this is higher than your SLAM level.
    CC 1 Looks like something may be growing in the water.
    Ph 8.2 Too high.. need to bring this down using muriatic acid
    TA 150 High, which contributes to your pH being high. When you drop your pH with MA, this will start to come down also
    CH 250 Ok for a pool with a heater
    CYA 20 Too low for a pool in hot sunny Austin. CYA this low will also make the FC disappear faster.
    Here are suggested levels for pools: Pool School - Recommended Levels
    Assuming your water is clear and no signs of algae:
    Get some stabilizer in there, enough per PoolMath to bring it up to about 70ppm.
    You should also check your salt level because if its too low your SWG may not be working optimally.
    Let the FC drop to match your CYA level- see this: FC/CYA Chart
    Drop your pH with Muriatic Acid using Pool Math to guide you.
    If you're not sure if your pool is vinyl, one way to know is does it have a fake printed tile pattern on it? Got a picture you can share?
    May 2015
    Austin, TX
    118
    The FC went from zero to 15 within 2 hours of my dropping 2 pounds of chlor brite powder into the pool.
    The water is very clear and clean. I see a small spot of green algae about one inch size at the bottom of my spa. Nothing in the pool, the pool floor is clean.
    How do i increase the CYA ?
    Jan 2012
    7,264
    You can buy it in 4 pound jugs at Lowes, or Walmart. It is called Stabilizer or Cyanuric Acid. Look in the pool section.
    Put the proper amount in a sock and hang it in front of a pool water return to dissolve. You can squeeze it now and then to help speed it up. It will put out white cloudy water but it won't hurt you. After its all dissolved wait a day or two and re-test.
    May 2015
    Austin, TX
    118
    I got this cyanuric acid stabilizer from walmart today. I put 12 oz in each skimmer of my pool and running the pump now. Is adding it to skimmer the proper way to do it ?
    May 2015
    Austin, TX
    118
    I am not sure where my pool water return is, and even if i found it how would i hang it there in a sock ? Use a stick with a string tied to it ?? After i added the stabilizer crystals to the skimmers i dont see any white cloudy stuff yet
    Jan 2012
    7,264
    no, if you put it in the skimmer (and assuming it didn't clog the pipe) it is now in your filter....slowly dissolving there. No backwashing for about a week so you don't lose it until its fully dissolved into the water.
    We don't recommend putting it loose in the skimmer or the water, but doing just as you said-hanging off a stick works great. I also hang if from some pool noodle that floats around my pool. You just don't want it sitting against the wall or loose on the floor of the pool as its kinda acidic and might stain/bleach the liner.
    Your returns are the little round places in the pool wall that water shoots in from the pump.
    addendum: PoolMath says that to take your CYA from 20 to 70 will require 100 ounces of stabilizer. Go slow, you already added 24ish ounces, right? Try another 50 and then give it a few days and retest. Better to creep up on the goal rather than risk over-doing it.
    May 2015
    Austin, TX
    118
    Oh no ! I should've followed your sock idea. I put it in the skimmer because thats what it said on the directions to use on the jug of the stabilizer
    Jan 2012
    7,264
    Don't sweat it.. we tend to advise folks on the safest way to do things with the least chance of problems. You'd know by now if you'd had a problem, but it is harder to determine when the granules are entirely dissolved when they're in the filter.
    May 2015
    Austin, TX
    118
    Is it okay to store these pool chemicals like stabilizer, muriatic acid, pool salt, baking soda outdoors in the texas heat . They will be covered inside a large deck box beside my pool. The temp in summer can be 100 and winter 35
    DFW, TX
    24,450
    Everything except bleach and the test kit can be stored outside. Best to keep MA separate from other stuff. I store mine outside in the shade.
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    If the MA has been opened, don't ever put it in the shed with garden tools. It will rust them in a very short time, been there done that.
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    Jan 2012
    7,264
    MA and bleach both have vented lids. MA and Chlorine DO NOT play nicely together... in fact they make a poison gas. So you should never keep them near each other or store the MA near metal. I keep mine in a plastic cabinet next to my pool filter with the rest of my chemicals (which actually are few) in the pool house.
    Once MA and Chlorine Bleach are added individually to the pool water and mixed they're fine, just put about 15 min between additions in the water.
  20. Back To Top    #20
    May 2015
    Austin, TX
    118
    I conducted another test today. This is after adding 24 oz of stabilizer yesterday, and 1000 ml of MA. Ph dropped and cya went up. FC is still high. Plan to add more stabilizer today. Please advise next steps. Can the pool be used by me and two kids in this state ?
    FC 6
    CC 0
    Ph 7.5
    TA 160
    CH 225
    CYA 30
