Thread: Confused about connecting
    LittleTagAlong's Avatar
    Jun 2016
    Amarillo TX
    119
    I bought a Hayward AquaCritter auto vac. When I read directions on setting it up, I just can't understand. Of course, since mine is an Intex pool with over the wall (not in) skimmer, the instructions don't really apply. Do I need an adapter or just bypass skimmer and attach to sand filter? Help, please, I'm tired of vacuuming with the hand vac that isn't cutting it.
    AG, Intex 18' x48" Easy Set pool( =/- 5455 gal)
    Intex SF80110 sand filter & SWG ECO 7110, Hayward AquaCritter
    Well water, location is north Texas, usually up from late May to Oct.
    Taylor TF-100 test kit, TDS Digital Salinity meter and Taylor salt kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Confused about connecting
    you may need to plumb in a T valve to connect it into your suction side
    have you thought about installing a through wall skimmer
    Jun 2016
    Amarillo TX
    119
    I was looking at those today. but for the moment don't want to drain pool to install. Thanks for help.
    Going to try something. Disconnect from skimmer and attach vac to sand filter line. I am putting panty hose in filter basket. Just a test.....
    Jun 2016
    Amarillo TX
    119
    Update : Got it done! I ended up using the vacuum part from my Intex kit, an 1 1\4 PVC elbow, and a large rubber washer that I had. Will post pics and video when I get to my computer
