Thread: Things I learned from TFP site...
    Apr 2016
    South East USA
    78
    I learned some great stuff from the TFP site and it has made a world of difference to my pool.
    Please add to the list:
    1. A test kit is very important.
    2. Using a test kit I can balance my pool and get sparkly water using (mostly) grocery store products instead of expensive pool store products.
    3. Using a test kit and grocery store products I can balance my pool for the season for less than $100, instead of at least $300 - $400 using pool store products.
    4. Once my pool is balanced I can run my pumps for just 3 - 4 hours a day instead of 9 hours, saving electricity and wear-and-tear.
    5. Once my pool is balanced I can set SWG output to 30% - 50% instead of 100%.
    6. Before opening pump to get the strainer, switch the valve to 'closed' to prevent water from flowing back to the pool. The pump will prime much faster.
    7. I can use a return jet easily to fill the hose for vacuuming.
    8. Pressure gauges ARE useful.
    9. I only need to backwash when my pressure gauge reads 10% above normal (See # 8).
    10. A rock is the most practical item to prevent the skimmer basket from floating.
    Cheers,
    ft
    ~22,000 gallons, freeform, Pebbletec, beach entry AquaRite SWCG v1.33 Hayward Tristar SP325EE pump for main draw & skimmer Hayward sand filter S310S 1.5 hp booster pump Paramount PCC2000 in-floor cleaner, skimmer, debris containment canister Waterfall Pentair Intellibrite 5g LED light in Pentair stainless wet niche Jandy Lite2 heater: removed Auto-fill: deactivated
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Things I learned from TFP site...
    Very nice list isn't it great...
