Thread: Pool timer losing time
    Apr 2015
    herndon, va
    8
    Hi, my pool timer is losing time, it's working, but losing an hour or so every few hours. It looks pretty old, some of the casing and the cogs behind it are pretty rusty. Could this be more than one thing? I assume there's a timer motor and then a mechanism that that drives the 'face' and it could be either or both parts? How do I isolate the issue? It's a intermatic T104M.
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    357
    Re: Pool timer losing time
    Isolate the issue by replacing it. An old Intermatic is a replaceable part.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Jul 2016
    Punta Cana, LA
    6
    Quote Originally Posted by Richakn View Post
    Over the time the motor that drives the clock suffers some wear and it seen to slow down , if you feel comfortable working with electricity and are DIY incline you could easily replaced the motor from around 25-30 dollars. You can find it following this link.
    Amazon.com : Intermatic WG1573-10D 60-Hertz Replacement Clock Motor for T100, T170, T100R201, T1400, T100-20 and WH Series : Swimming Pool Heater And Heat Pump Parts : Home Improvement
    If you look around you can find a plastic housing to replaced your rustic one.
    Enviado desde mi 6039A mediante Tapatalk
