Results 1 to 9 of 9
Thread: Yellow Out
    Jul 2016
    slidell
    58
    Yellow Out
    This may help persistent algae, go to walmart or Loews and look for Yellow Gone (2 lbs) and follow instructions (very easy to do results should be impressive) (then need to add 2 lbs cyanuric acid afterwards). helped my Louisiana pool.
    Blue haven kidney style 16,000 gal gunnite including Spa, test Kit TF - 100
    Built 2000 deep end 7.5 feet, 2 steps at shallow end
    Original SWG then convert to chlorine
    Pentair Clean & Clear cartridge filter (4)
    Blue Haven Teledyne Laars Platinum II heater
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,866
    Re: Have automatic chlorine generator on high, but FC is almost always zero
    Quote Originally Posted by 63john View Post
    We would never reccomend adding something blindly without understanding the chemical compound and the effects of said chemical compound on pool water.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jul 2016
    slidell
    58
    Yellow Out
    a decent commercial remedy is YELLOW GONE at Walmart, follow simple instructions, worked for me pool looks great no algae.
    Jul 2016
    slidell
    58
    Yellow Out
    try YELLOW GONE at Walmart or Loews a fantastic algae remover product simple instructions drop right into pool where spots are then add super chlorinator afterwards, algae dissappears in 6 - 8 hours during daytime
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,866
    Re: Another Algae Bloom
    We do not advocate adding things to your pool without understanding what chemical is and how it will react with pool water.
    Jun 2014
    14,970
    Re: I need help.. major algae issue
    I wouldn't recommend the yellow based on previous discussions and experience here for normal pool use.
    Jun 2014
    14,970
    Yellow Gone is not normally a product advised for use here at TFP as noted HERE.
    Donldson's Avatar
    NW Ohio
    2,880
    Re: Yellow Out
    I must know, did you research what is in Yellow Gone, see what it does to the pool chemistry and then make the decision to introduce it in your pool and base your recommendations upon that knowledge?
    Or did you just buy something at Walmart, dump it in your pool without knowing what it is or how it works, see it helped and decide you must tell everyone to use it without knowing how it will affect their pool chemistry?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jan 2012
    'burbs of Augusta, Georgia
    7,252
    Re: Yellow Out
    Since adding that product.... how's your FC holding up?? It usually causes a problem there.
