Thread: Question on CC test for TF-100
    Jun 2016
    Long Island, NY
    21
    Question Question on CC test for TF-100
    After you do the FC test and you add the 5 drops of r0003 it says if it returns to pink if you have cc's. My question is, the 'pink' they refer to is it the dark pink like when you first add the powder or any shade of pink? Reason I ask, is sometimes after adding the r0003 it goes to a very light shade of pink and after 1 drop of r0871 it goes back to clear so I am assuming .5cc?
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: Question on CC test for TF-100
    If it turns any shade of pink when you add R0003 then you have CC. You're .5cc in the example above is correct.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
