Thread: NFG trying to figure it out
    Jul 2016
    Hatfield
    17
    I just got my test kit.
    I am reading FC .6
    CC 5.8
    Ph 7.4
    CYA over 100
    Does this make any sense? Any tips to get moving in the right direction? Feeling overwhelmed
    Previous owners told my to replace pucks often. and use non chlorinated shock often. Learning I should probably not be doing this. Bout to hear to Wallyworld for bleach.
    Thanks for any tips, sorry for being such a newb.
    Jan 2012
    'burbs of Augusta, Georgia
    7,239
    Re: NFG trying to figure it out
    Which test kit did you get?
    How does the water look?
    Where is Hatfield?
    How hard would it be for you to drain and refill some of your water??
    What kind of pool surface and equipment do you have?
    Non-chlorine shock (aka MPS) will show up as CCs in testing, which is not accurate.
    Your FC is entirely too low if in fact your CYA is 100 or more. Need more information on this.... such as performing a dilution test for the CYA to see how much over 100 it may be?
    Jul 2016
    Hatfield
    17
    Thanks for the reply.
    I'm in Pennsylvania.
    I have the Taylor K-2006
    Vinyl lines, sorry, I thought I set up a signature.
    Water is clear, Algae shows every few days though.
    I can drain to a sewer grate and refill via hose pretty easy.
    20,000
    IG Vinyl
    DE filter
    Well filled
    Jul 2016
    Hatfield
    17
    So I decided to do a partial drain. 20,000 gallon pool, drained down to maybe 20 inches in shallow end. Filled up with water, tested again....
    CYA is still over 100. I guess I have to drain again, huh.
    Sucks. Its takes so long to do this, we just want to swim!
    20,000
    IG Vinyl
    DE filter
    Well filled
    Jan 2012
    7,239
    Ouch, yeah.... it's a shame but with CYA that high its near impossible to keep the water algae free. After you refill again, run a full set of tests and tell us:
    FC
    CC
    pH
    TA
    CH
    CYA
    ....and no more Non-Chlorine Shock please! Stick with the liquid chlorine. Hang on to the pucks for times that they *can* be used such as vacations, as long as you're aware of the CYA they will add.
    Have you read this yet? --> ABCs of Pool Water Chemistry
    FC
    CC
    pH
    TA
    CH
    CYA
