Thread: Pump broken - is using Aquabot enough?
    Hi, my pump is down which means my salt chlorination is down too. Repair is scheduled for mid next week.
    My question is do you think I need to do more then adding bleach as needed to keep chlorine at the right level and run my Aquabot turbo T for 7 hours a day to keep things under control until the system is back up and running?
    Of course I am skimming manually as well.
    Thanks for opinions.
    2008 23K IG Liner, Pentair intellipump vf, 48DE filter, Heatpump, SWC, aquabot turbo T, K2006 Testkit
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump broken - is using Aquabot enough?
    That should work.
    Mark
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Just remember to dose like a manually chlorinated pool during this time, since you won't have the constant low chlorine production for several hours a day. FC/CYA Chart
    Love TFP? Become a
    TFP Supporter!
