Results 1 to 8 of 8
Thread: $bleach~tabs$
    stevenmverrill's Avatar
    Nov 2015
    Frederick md
    30
    $bleach~tabs$
    Best deal on bleach at my local weis is 2.20$ for 12.5% i bought 8 gallons. Asuming bleach is about 8lbs a gal. Looks like 2.20 a lbs.
    I have a chloranter, and amazon prime. I see 50lbs of 98% chlorine for 94$ thats around 2$ a lbs.
    I am nervous about tabs having too much cya but, some cheep amazon tabs i doubt have much if any.
    What i am currently thinking is to matain with tabs and shock with bleach. Any one see a down side to running cheep tabs insted of bleach?
    18x36 rectangle built early 90's, 9ft well, "black onyx" vinyl liner, 1 1/2" plumbing, 2 returns, 1 skim, 1 drain/return, plumbed chloranter, 48sf de filter, multi port valve, and 1.5hp jandy pump.
    May 2016
    MD
    195
    Re: $bleach~tabs$
    You must live near me... I am in Adamstown.
    don't do the tabs. all you need is bleach... test it once a day and add what you need.
    Not sure what your test numbers are though...
    Guess I need to find this Weis you speak of...
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: $bleach~tabs$
    Any solid form of chlorine, be it tabs, powder or granules add something to you pool water that you don't want or need. With tabs it's CYA, most powder forms it's calcium. Using tabs will lead to a buildup of CYA and an over stabilized situation where you will need to maintain higher and higher chlorine levels, until it is unmanageable and you are forced to drain the pool to regain control. This is the reason TFP doesn't recommend tabs for chlorination.
    I strongly recommend that you go to Pool School (it's the button at the upper right corner of this page), do some reading. It may seem a bit confusing at first, but with some study it all begins to make sense.
    chiefwej
    Nov 2015
    Frederick md
    30
    Re: $bleach~tabs$
    Thats cool i almost bought a house on plesent view rd. Ended up between Ijamsvill and frederick.
    The weis in spring ridge off 144 has a pool aisle. "Austins pool tech shock" is what its called. Weis bleach is less then 2$ but its 5%.
    May be. Worth it for you to try the weis on the golden mile first befor coming all the way up here.
    May 2016
    MD
    195
    Re: $bleach~tabs$
    My in laws live close to the one near the golden mile... and the mall will soon turn into a Wal mart.
    Nov 2015
    Frederick md
    30
    Re: $bleach~tabs$
    Cool. My old house was in emerald farm. So they are finaly doing something with that wortless mall! About time. Im happy as long as home depot stays.
    Donldson's Avatar
    NW Ohio
    2,884
    Re: $bleach~tabs$
    Quote Originally Posted by stevenmverrill View Post
    Tabs are made of trichlor. Cheap ones, expensive ones, ones that come individually wrapped, ones that come in giant buckets. Trichlor is a compound made of chlorine bound to CYA. There is no such thing as "low CYA" tablets unless they are also "low chlorine" tablets. For every 10 ppm FC added by trichlor, 6 ppm of CYA is also added. This is a constant, it does not change.
    I don't understand why you are comparing weight, that has nothing to do with it. 1 gallons of 12.5% chlorine will add to 10,000 gallons 12.5 ppm FC and some salt. 1 lb of trichlor will add to 10,000 gallons 11 ppm FC, 6.7 ppm CYA and some salt. No real difference in price per FC added. Trichlor is also quite acidic so you will need to purchase soda ash to keep the pH and TA from dipping too low, extra cost to tablets. You will also need to change the water when your CYA rises too far, more extra cost to tablets.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Nov 2015
    Frederick md
    30
    Re: $bleach~tabs$
    Thanks that anwsers that. Bleach it is. Just using 25lbs of tabs has my cya is at 50. If i finshed the seson id be over 100. My lbs:cost was just that but you
    Mostly riped that apart.
    Bleach it is.
    Now back to vacuming. (guests tonight) btw hand vacuming is fun! I vacuumed a few days ago, and its hot so i want to swimm. Goggles and an oppen hose swimming around like a gost buster is fun... Lol
