Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Using Standard CYA - Dot disappears at 40, not 50
    May 2015
    Land O Lakes, FL
    527
    I just got the Cyanuric Acid Standard 50 ppm solution.
    Added Standard 50 ppm solution (R-7065) to the sticker, then added CYA Reagent (R-0013), shake wait 30 seconds, shake again, then test. Sun to my back at waist level.
    Ran the test 2 times with new reagent each time. Both times, the dot disappeared at 40 ppm, not 50.
    I know there is a swing factor but if I am off by 10 and then a swing factor of 10, I could be off by 20 and that could have a impact.
    Should I just relabel the CYA test tube?
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Using Standard CYA - Dot disappears at 40, not 50
    I found the same thing when I did it several times. On a really sunny day I was able to get it halfway between 40 and 50. The key is holding it at the top so as much light can flood in as possible. Taylor says that their standard sample is correct so what you are seeing is actually 50 ppm. So, I just round up to the next 10 if in doubt. A little more is better than a little less in my opinion.
    AUSpool's Avatar
    Sep 2015
    Sunshine Coast, Australia.
    358
    That's kind of what works for me too. I've just started to need glasses for reading so it's important that I do the test with glasses. I stand infront of a window or in full light to get as much light into the vial as possible. Fill it up till the dot disappears, look away and look back a few times and adjust to make sure it's disappeared. This is changing and readjusting my focal length. I then add two extra drops for good measure and I'm done. This won't work for everyone but it works for me and I'm going to keep running the test with the standard solution every so often just to make sure that that method is still the best for me.
    Steve.
    30,000L (8,000g) Pebblecrete | Davey 3sp Eco pump | Poolrite sand filter & SWCG |
    Waterco solar panels & Astral E140 pump| K2006, BlueDevil pH, Salt meter & K1766 | Town water - pH 7.2, TA 50, CH 60 | Esky full of coldies |
    Feb 2016
    Gilbert/AZ
    11
    I didn't have a lot of confidence in my CYA test results so I ordered up the CYA standard solution to confirm I was doing it correctly. Like you, I couldn't find proper lighting, hold technique, star alignment etc...to make it work correctly. I found that filling the CYA reagent to the top of the label was very inconsistent. Specifically, getting the bottom of the meniscus to the label top results in the liquid level encroached on the neck of the bottle throwing everything off.
    Long story short, grab a graduated cylinder and fill the Standard Solution to 15ml and then the reagent to 30. Pour it into the normal CYA mixing/measuring bottle and then run the test as usual.
    This made the test accurate for me and now I have much more confidence in my CYA tests.
    Good luck!
    CFM
    18k Gallon, IG Pool & Spillover Spa, Pebble Tec, SWG, Cartridge Filter, TF-100
    May 2015
    Land O Lakes, FL
    527
    Quote Originally Posted by CFM56-7 View Post
    Good luck!
    CFM
    Interesting that you describe it this way, i agree completely. . I redid the test 3 tumes because i kept "missing the mark" wirh the fill bottle as well.
    Matt
    AUSpool's Avatar
    Sep 2015
    358
    Quote Originally Posted by mgmoore7 View Post
    Ive got a K-2006, the instructions say to shake for 30 seconds then slowly fill the view tube. I was coming up short with the sun to my back to, it works better for me with the sun infront of me or where I'm not blocking direct light but not nessarary direct sun.
    Last edited by AUSpool; 07-17-2016 at 11:17 PM. Reason: tube with dot replaced by view tube.
    Steve.
    DFW, TX
    24,516
    Interesting, I guess it depends on time of day. My best results are with the most light flooded in from the sides but no light going in the top of the tube
    30,432
    We are still doing some experiments. It appears the K-2006 comparator is yielding 50 more often and the TF-100 test tube and the Taylor 9193 (20-100 ppm) are yielding 40.
    We don't yet have conclusive info but we are doing some more work to get to the bottom of it.
    Saturn94's Avatar
    Mar 2015
    Virginia
    501
    I have the K-1721 Kit with the 9197 tube (30-100ppm). Any idea if it's affected?
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    30,432
    well, I am not sure "affected" is any part of what we are doing.
    We are simply doing side by side comparisons of the various view tubes and reporting what we see as our results. We'll report what we see with the 9197 soon - it is not an item we inventory.
    Everyone remember that this is a very subjective test and there may be no absolutely "right" answer. The precise amount of CYA in your pool will only be your best judgement.
    You are looking for stability with CYA so if your readings are consistent, you are reading the CYA test correctly.
    CYA results from 30-80 can all work just fine in different pools so we all may have to be a little subjective when we do this test.
    Saturn94's Avatar
    Mar 2015
    Virginia
    501
    It'll be interesting to see your results.
    AUSpool's Avatar
    Sep 2015
    358
    That 9197 looks similar to the CCL one available to us in Aus. I was thinking of getting one and do away with the view tube / pH comparator combo that came with the K-2006 since I don't use the pH comparator. When using the view tube in the comb there is no need to directly hold the tube where the 9197 or CCL equivalent would need to be held, possibly reducing light transmission. I wonder if we will now get specific instructions on how to hold this tube.
    The instructions that come with the CCL CYA kit don't offer any specific instructions on how to hold the view tube but do say that the accuracy of the test is dependant on the brightness of the ambient light - nothing new there I guess. I guess I would just have to test my method with some standard solution.
    Steve.
    May 2015
    Land O Lakes, FL
    527
    Dave
    Did you come to any conclusions or theories with your testing?
    Matt
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,156
    As we all know, the CYA test is a subjective test as everyone has a different "opinion" as to when the black dot disappears. Personally, to me, the 9193 and 9197 view tube seem to yield closer to 40 ppm and the K-2006 comparator seems to yield closer to 50 ppm using the CYA standard, R-7065. With that being said, TFTestkits is going to hold off on selling the R-7065 as it also yields closer to 40 ppm using our TF-100 view tube.
    May 2015
    Land O Lakes, FL
    527
    Quote Originally Posted by OTPirate View Post
    I think all of us wish there was a better way. The CYA has a notable impact on the TFP way yet so many of us and even experienced TFPers appear to have difficulty.
    Just this last weekend, my CYA dropped 20 ppm compared to the last time even while attempting to keep all variables the same. I effectively just through it out as a testing inconsistency and will try again this weekend. I tried to use the standard solution to help but it just added more confusion...
    Matt
    DFW, TX
    24,516
    While knowing the CYA level is critical to TFPC pool management for setting FC level the accuracy of the CYA number is not so important, +/- 10 ppm, etc. It just doesn't make that big of a difference to the FC level in the pool. Generally, each increase of 10ppm CYA calls for 1 ppm increase in FC. So, if in doubt keep your FC 1 or 2 ppm higher and you will be well covered on the margin of error. And as we know it is safe to swim with FC up to shock level for your CYA.
    CYA 40 min 3 target 5 shock 16
    CYA 50 min 4 target 6 shock 20
    If you aren't sure if CYA is 40 or 50 then keep FC above 4 instead of above 3 and/or target 6 or 7 instead of 5 or 6 and the margin of error is covered.
    May 2015
    Land O Lakes, FL
    527
    Quote Originally Posted by pooldv View Post
    This is what I am doing and that is fine but I have tons of reading now, maybe more interest in this than some and dozens of tests under my belt. Still a newbie compared to many, but not for the new reader of TFP needing to get a kit, test and then start a SLAM.
    For example, if they are off by 10-20ppm, and then add a +/- 10, the impact could be notable. In the charts, it does not say, if you are not sure on your CYA, keep your FC higher. I have figured that out but that is after a few months of consistent effort and reading and "getting it" in regard to the relationship of CYA to FC, daily FC loss, target and minimum.
    I have concluded now what most of you probably have already concluded, we just have to do the best we can with what we have and allow experience in testing and managing our own pools to teach us.
    Matt
    30,432
    If your variables were consistent, then your CYA dropped 20 ppm.
    So, since that really makes no sense, it is pretty safe to assume some variables changed.
    Mar 2015
    Georgia
    157
    So are the 9193, 9197, and TF view tubes wrong or is the R-7065 solution not 50 ppm?
    16k AG Vinyl Sand Filter
  20. Back To Top    #20
    DFW, TX
    24,516
    What we always say is to round up your CYA to the next 10. Your CYA test will always be better than the pool store, more consistent and more accurate. We have seen pool store test results of the same water vary by 50, 100 and more. And test strips? Might as well dip a finger in the pool and take a guess.
    Each pool does have its own variables, climate, sun, shade, pets, birds, wild animals, number of swimmers, with or without lotion, perfume, hair products, chemistry of fill water. It is important to learn and understand your own pool and it's variables. That is why nearly everything has a recommended range and not just a number.
    In all cases TFPC is always better than being pool stored.
