Thread: New owner / First TF-100 reading
    Jun 2015
    East Meadow/NY
    82
    Hello everyone,
    Now that the pool is in I need to start reading up on how to maintain. Here are the first readings I'm getting after the pool has been filled. I hope I am doing this right:
    FC 3.5 ppm
    CC .5
    TC 4.0
    PH 7.2
    CYA - this is where I'm confused. I know when you just fill the pool there is no CYA. I purer my sample in the tube and I filled it way to the top and still see the black dot. I did check if I was doing it right so I used the pool water sample in the kit and had a reading of about 50.
    TA 50
    CH 100
    Now what?
    14x22 radiant freeform, 6800 gallons, Semi AG, DE Hayward, Hayward SP1580X15 Power-Flo LX Series 1-1/2-HP, installing 7/14/2016, TF100
    Jun 2015
    East Meadow/NY
    82
    Re: New owner / First TF-100 reading
    Also I ran the pump for 24 hours to get to temp and I turned off the pump last night and have it scheduled to run from 8am to 4pm. Is that too long? The water is crystal clear and I vacuumed the pool.
    30,431
    Now you get some CYA in your water. Dose carefully using poolmath to about 40 ppm.
    Next, you have to understand what those results mean. read "The ABC's of Pool Water Chemistry" up in Pool School. That'll tell you the normal levels you are seeking and will tell you why they are important and it will tell you how to maintain them.
    Jun 2015
    East Meadow/NY
    82
    Great thank you. Are my readings ok to go swimming?
