Thread: pink algae
    Jul 2016
    Gaylesville / Alabama
    1
    pink algae
    how do I get rid of the pink that is starting I have a 15 ft round pool with a sand filter it is 52 inches deep ?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: pink algae
    Welcome to TFP!
    We kill pink algae the same we kill regular algae, by following this process, SLAM. You will need a good test kit. I use the TF-100 from TFTestkits.net. I hve been buying my kit here for years. It is the best value, Pool School - Test Kits Compared
    Donldson's Avatar
    NW Ohio
    2,881
    Re: pink algae
    Welcome to TFP!
    Something we need to ask before giving advice is what you are using to sanitize your pool. Pink algae is much more common with Baquacil pools than with chlorine or bromine. Are you using Baquacil, chlorine, or bromine to sanitize your pool?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    DFW, TX
    24,450
    Re: pink algae
    On that note, please fill out your signature so that we can better help you. More here on what to put in your signature and how to do it, Pool School - Read This BEFORE You Post
