Thread: Beginner Starter Pool just filled - few questions
    Jul 2016
    Cibolo TX
    4
    Question Beginner Starter Pool just filled - few questions
    So I have been trying to read but haven't found my exact questions answered. Sorry if I missed an easy thread previous post
    This pool I just filled last night. I am running the filter (cartridge one that cam in the box)right now, filled with garden hose, plan on running the pump for 6 hours a day per instructions.
    can my three girls swim while the pump is working?
    how long after I add the 6% bleach do I need to wait until they can swim?
    manual says something about adding 1" tablets to my pump. Should I do this or buy and use the chlorine tab floater? or stay with bleach since its a small pool?
    I did buy this walmart chem kit Hth Pop Up Pool Kit - Walmart.com but haven't added anything yet. This is the test kit I plan to use Kokido 5-Way Reagent Swimming Pool Test Kit | Academy (I have to take it back this morning, something leaked inside and got the instructions all wet and unusable, will be there at 10am CST)
    Thanks in advance
    Torrch5
    2600 gal AG; Cartridge filter; Big Lots Summer Waves 14' x 36" Quick Set Inflatable ring Pool - (AG pool in a box, starter pool to see if i can do it before going bigger); Pool cover (cover nightly) academy sports store Kokido 5-Way Reagent Swimming Pool Test Kit; fill with garden hose, water restrictions to water on fridays only
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    880
    Re: Beginner Starter Pool just filled - few questions
    Welcome to the forum Torrch5.
    To answer your questions-
    -I always run my pump when my kids are swimming in the pool -I like the fact that the water and chlorine in particular is being circulated
    -You can wait about 15 minutes with the pump running after adding bleach to swim
    -I think you would find it easier to maintain the pool with bleach or liquid chlorine, adding stabiliser as a separate component. Tabs add chlorine and are convenient but they also add stabiliser (AKA- CYA) which can become problematic when it gets too high and certainly for your situation would be easier.
    Try reading this Guide-for-seasonal-temporary-pools
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Aug 2013
    Otsego, MN
    79
    That drip test is better than the strips that come with the HTH pack, but you can't test CYA with it.
    This forum doesn’t generally recommend powdered "shock" products or pucks/tablets.
    Check out pool school for more info.
    Pool/Equipment: 20'x52" round Intex Ultra Frame AGP (~8,800 gallons)--Intex SWCG (CG-28669, 15K gallon model)--Intex Sand Filter Pump (SF60110, 16", 120lbs sand, 3K gph)--Hayward SP1091LX Through-Wall Skimmer--Hard Plumbing--Taylor K-1766 Salt Test Kit--TF-100 Test Kit
    Jul 2016
    Cibolo TX
    4
    thanks for the responses!
    Jul 2016
    Cibolo TX
    4
    oh so looking at the pool math calc, i get
    Size 2600 Mouse over a field for detail
    FC Goal: 3 to 7 Add of % bleach. Jug size 96 oz 128 oz 174 oz 182 oz 30 oz 64 oz 121 oz .
    or add by weight or by volume of trichlor dichlor cal-hypo 48% cal-hypo 53% cal-hypo 65% cal-hypo 73% lithium-hypo chlorine gas .
    Note: Dichlor and trichlor add CYA and lower pH. Cal-hypo adds CH.
    is this saying I need to add 96 oz of bleach, correct? what is trichlor?
    Quote Originally Posted by Torrch5 View Post
    Again I just filled this last night and this morning.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Welcome to TFP!
    Time for a little reading in Pool School to learn what is what.
    Start here, ABCs of Pool Water Chemistry
    And here, Pool School - Getting Started
