Results 1 to 11 of 11
Thread: The pool is ours...
    aguyindallas's Avatar
    Apr 2016
    Little Elm, TX
    127
    The pool is ours...
    Well, the builder has turned it over to us now and they are working on a few final punch list items. They gave me the proper set points for my pool (don't have those with me right now) and advised I buy a better kit than what they give us. I am pretty sure they use the TF100 or the K2006. Their cost is 97.00....and I know I can get it here for much less. Anyway, we have a Saltwater pool. Which kit is best for me to get and do I need to get any other test items (strips etc) to go with my kit?
    11.5K Plaster, level spa, Salt with Pentair Equipment.
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: The pool is ours...
    Strips are useless other than for quick, "ballpark" checks to be followed up with TFP recommended test kits. Congratulations on your new pool!
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    Aug 2013
    Otsego, MN
    79
    Get one of the recommended test kits and add the Taylor K-1766 (I believe) salt test kit to it. I would buy (actually, I DID buy) the TF100.
    Pool/Equipment: 20'x52" round Intex Ultra Frame AGP (~8,800 gallons)--Intex SWCG (CG-28669, 15K gallon model)--Intex Sand Filter Pump (SF60110, 16", 120lbs sand, 3K gph)--Hayward SP1091LX Through-Wall Skimmer--Hard Plumbing--Taylor K-1766 Salt Test Kit--TF-100 Test Kit
    Apr 2016
    Little Elm, TX
    127
    Quote Originally Posted by 911medic View Post
    I will pull the trigger on the TF100...but I am not sure I need the K-1766 only because my Intellichlor system tells me the salt PPM on the fly without any testing needed. Can anybody advise on me still needing the K-1766?
    Saturn94's Avatar
    Mar 2015
    Virginia
    499
    Quote Originally Posted by aguyindallas View Post
    A salt test is good to have to verify the SWCG is operating properly. It seem to be a common symptom that when the salt cell is dying it will give false low salt readings/false low salt warnings. If you only went by the SWCG in this situation, you would just keep adding more salt until you realized something wasn't right, ending up with high salt requiring water replacement.
    I know many here only recommend the Taylor salt kit, but I find the AquaCheck salt strips accurate enough for this purpose; they've always been within 200ppm or so of my SWCG reading in my experience (when the SWCG is operating properly).
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Apr 2016
    Little Elm, TX
    127
    One other question about this....should I get the TF100 or the K2006?...what is the difference?
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    I have and like the 2006 but may have overbought. Think you'll be fine with the TF100.
    Apr 2016
    Little Elm, TX
    127
    Quote Originally Posted by Frankhugus View Post
    So the 2006 is "more" than the TF100
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    http://www.troublefreepool.com/conte...its-comparison
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Apr 2016
    Little Elm, TX
    127
    I went ahead and ordered the TF100 and the K-1766.
    Aug 2013
    Otsego, MN
    79
    You'll be glad you did.
