Results 1 to 8 of 8
Thread: Fiber optic lens
    Jul 2016
    selkirk
    4
    Fiber optic lens
    Hi,
    New to the site and inground pool. I have fiver optics in and around pool. The perimeter lights are shot and I have pulled those strands from the light source. Only 2 of the 4 wall lights are working and they are very dim.
    The bulb is very bright and blinding and strands appear to be clean on that end. The pool sat for over a year unattended and needed major cleaning. Is it possiblt the lenses are caked up with crud and alge?
    Do I need to drain down water below the lights to remove lens cover, or is it ok to just take out as is? Just wanting to inspect and clean.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Fiber optic lens
    The short answer is you need to turn off the breaker out of an abundance of caution and then you can work on the termination of the light strands into the pool. No need to drain.
    How old is the system?
    Are the light generators working properly?
    Are the light generators on a GFCI circuit? They should be and more than 5 feet from the pool edge.
    Inyo pools sells replacement parts and there are other sellers.
    Jul 2016
    selkirk
    4
    Quote Originally Posted by gwegan View Post
    I do not have any idea on the age of lighting system
    it appears that everything in box is working. The color wheel rotates, the fan works and the bulb is bright
    there are 2 GFCI boxes in light box, however, it is maybe 5-6 feet from pool. More closer to 5
    So what your saying is I can remove the 4 screws holding the assembly while still submerged and bring to pool deck to clean/inspect? Or do I need special tool to remove only the lens?
    Apr 2013
    Sacramento, CA
    2,769
    You should be able to remove the crews and bring out the lens.
    Is this a fiberstars?
    Inyo pools has schematics. Go to their site and search illuminators fiberstars
    Jan 2012
    340
    Most fiber optic lenses are threaded into a wall fitting, not requiring any screws to be removed.
    Can you post a picture?
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    Jul 2016
    selkirk
    4
    Quote Originally Posted by thepoolman View Post
    Its not the best picture
    Jan 2012
    340
    There are 4 notches in the clear lense. You should be able to spread a pair of needlenose pliers between two of them and spin it out.
    I believe you will need to drain the water just to inspect/clean.
    Jul 2016
    selkirk
    4
    Yes. I was advised to lower water before opening. I will leave them until fall
