Thread: D.E. "diatomaceous earth" grid leak and D.E. stuck on liner
    Jul 2016
    Holly, Michigan
    2
    Our filter grid had a small hole allowing D.E. to leak back into the pool. This went on for awhile before I figured out what was wrong. Now the pool liner is stained with D.E. that has hardened on the liner and no amount of scrubbing with a brush will dislodge. Any help would be greatly appreciated.
    24', 17K gallons, Above ground, vinyl, Sequel II Rotary DE Filter, Doughboy Pool Power-Pak II pump
    JoyfulNoise's Avatar
    May 2015
    13,213
    Re: D.E. "diatomaceous earth" grid leak and D.E. stuck on liner
    DE does not typically stain or stick to a liner. It should just vacuum back up easily. Can you get down to where the stains are and verify that they are actually rough and raised?
    Matt
    Jul 2016
    Holly, Michigan
    2
    Thank you for your reply. Yes, it is rough and raised. If brushed on hard for a long time it does clean it up a little. The leak was probably last year and sat over the winter.
