Thread: Please help identify my pool spa blower and its replacement
    Nov 2014
    CA
    10
    Question Please help identify my pool spa blower and its replacement
    Hi! May I ask the pros here to identify my spa blower please? I am also not sure what diameter and voltage.
    There are no stickers of any kind.
    I 'd like to replace it with a quietest blower possible as my neighbors before the blower broke complained about the noise.
    Infinite thanks in advance,
    In-ground plastered 15,000 gallon pool with adjacent tub 84" in diameter.
    Pentair FNS Plus 60 filter
    Pentair pump of some sort
    Pentair MasterTemp heater
    Master Pools in-floor cleaning system - dormant
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Please help identify my pool spa blower and its replacement
    Quote Originally Posted by Opel_Cadet View Post
    It goes by H.P. And the dia. Of the pipe.
    I replaced mine with a polaris unit, for about $ 200-250 bucks. I did a self install and bought a push button timer switch from home depot for about 30 bucks, it has 15-30-60 minute buttons so the blower will shut off after 1 hour and not get left on all night by the kids.
    You have to cut the pipe unwire the old one and rewire, you dont glue the pipe togther on the new one they give you a set screw to use and the blower has to be so many feet above the ground to keep from getting water pulled in it.
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    They have 240volt or 110 volt
    Thats the first thing you need to know
    Than there is 1 1/2 HP. Or 2 HP
    Oh and these blowers are quite !!! Lots of foam in them.
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Some pics of my setup
    Sean Hannon
