Thread: Replacing suction side valves under water level
    Sep 2015
    Brantford
    4
    Hey TFP'ers,
    I am replacing the suction side of a circulation system inside the pool shed. The equipment is below the water level. Admittedly, I forgot to look if there is a loop outside the shed so I am wondering if there are any tricks that would prevent water from feeding into shed once I cut away the 2 valves on suction side. I assume I can just position the filter head to closed to prevent flow from return side. I can also plug the skimmer but there is another valve for main drain. Both valves tee into the front of pump.
    I realize dropping water level will do the trick but it's balanced, heated water in the pool so trying to avoid if at all possible.
    Any ideas?
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,280
    Re: Replacing suction side valves under water level
    Glad the water is warm Dive in, remove the drain covers and bung them. Pump OFF and make sure someone is watching over you if you weight yourself down.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
