Results 1 to 14 of 14
Thread: Would anyone like to comment on this ? It's got really good reviews..
    Mark R's Avatar
    Nov 2013
    Desert Southwest, USA
    166
    Question Would anyone like to comment on this ? It's got really good reviews..
    It's from Costco so no issue with return. I'm very familiar with TFP method and follow it religiously. I thought maybe another set of eyes on this product might help. Would it help if I was on vacation for 5 days or even if I wasn't ?
    Sounds like it might help with chlorine usage as I use a gallon of 10% sanitizer per day during this ridiculous heat for 3 months. Seems like the reviews are excellent.
    Here's some pictures and a link to Costco site. I do have very hard water >800 in my pool.. Here are my numbers:
    Link: Chlorine-Free Sun Shock Pool Purifier
    CYA 60
    FC 7
    CC 0
    PH 7.4
    TA ? I need to check, it was 90-100 few months ago
    Pool temp is 90 degrees
    Is it worth a shot ? Not a replacement for TFP but as an addition.
    12k gal Gunite/Hayward filter C5520BH with quad 33 inch filters. 2.5 hp motor. Pool is on south side, so full sun light. Spill over spa.
    Laar's heater LT250-Low NOx Gas Fired for pool/spa 250,000 BTU. Roof mount 6 panel solar system installed east/south. TF-100 test kit. May-September 100+ degrees out side.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Would anyone like to comment on this ? It's got really good reviews..
    It's not recommended to add minerals... Not TFP, sorry
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    It's copper and silver. I would not use it.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Lots of folks here are spending a lot of time and money trying to remove copper and copper stains from their pools. Copper will accumulate over time and stain the water, plaster, hair, fingernails, dogs, etc. Also, copper doesn't sanitize pool water it only inhibits algae growth. The primary function of chlorine in your pool is to keep it sanitary and prevent person to person disease transmission.
    You can raise your CYA a bit more to help protect the FC from the sun better.
    May 2016
    Phoenix AZ
    128
    There are easier ways to make the mistake of adding metals to your water, and probably cheaper.
    Now, a solar powered chlorine generator I would buy.
    50,000 gallon plaster in-ground salt pool with two 60 sq ft DE filters, two Intellichlor IC60 SWGs, two Intelliflo VS pumps, two Whisperflo pumps, two Pentair 400K BTU NG heaters, PCC2000 in-floor cleaning system...two everything.
    Mark R's Avatar
    Nov 2013
    166
    Ok. I didn't understand it releases copper and other minerals into the water. The Ion would contain copper, I understand that now.
    Thanks
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Hmm, "ideal copper level 0.3" LOL
    The true "ideal copper level" is 0.0
    Run away from this product, and run fast.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Their write up is pretty misleading too. It is not impossible to have algae and copper in your pool! At $99 its also an expensive way to add copper to the pool.
    Love TFP? Become a
    TFP Supporter!
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Quote Originally Posted by Schadenfreude View Post
    Like this? Very expensive in my opinion, and not sure how it work...
    https://www.amazon.com/Natural-Curre...uckduckgo-d-20
    May 2016
    Phoenix AZ
    128
    Quote Originally Posted by Piolin View Post
    Hard to find reviews for this product, but I don't see how that solar panel could possibly generate adequate power to generate enough chlorine for anything bigger than a plastic kiddie pool.
    My cell runs 6A @ 24V, or 144W. A 145W solar panel is about 4ft x 4ft.
    I would guesstimate the panel for this to be reliable would be about 4'x8' and require storage batteries.
    How big is this cell?
    My Pool: 18'x36' Grecian. Vinyl Liner, 500# sand filter, SWG.
    My hobbies: Brewing beer and flying rockets.
    Just found it, 35"x35". It may be possible for this to function for a small pool.
    For 27000 gallons, I run my T15 cell.at 30% for 12 hours.
    Assuming conditions permit a 145W array to run at 30% duty cycle for 12 hours, it would power my cell. This is 56% of that area. So I'm guesstimating this would support a 15k pool for optimum (i.e. unachievable) conditions.
    Bottom line: At first blush it seems plausible for a small pool, perhaps <10k gallons
    May 2016
    Phoenix AZ
    128
    For that price, you can get a more reliable "traditional" SWG for a mid-sized pool.
    I love the idea, but I don't think we're there yet.
    Edit: this is about half the surface area of a 48 X 48 panel, so roughly 75 watts.
    Correction. The panel I had in mind wasn't 145W, but only 45W. Totally impractical...
