Results 1 to 9 of 9
Thread: Algae, Dirt, Sand??? Constant 2 year problem - pictures
    Jun 2014
    Wayne, NJ
    4
    Hello, wanted to see if anyone can help identify what is all over the bottom of my pool constantly for the past 2 seasons. Looks like brown dirt, but puffs into a cloud when I brush it. I can vacuum to waste and it will be there a few days later. This is in an above ground pool, I thought it was my cheap filter last season, but now I have a Hayward 21" sand filter/pump and I still get this stuff. My water is clear. My levels appear to be normal, chlorine is 4, PH is 7.4, alk is 100, CYA is 35-40. This is a 24' AG pool, 52" high. Anyone help identify based on pictures?? Thanks!!
    14,600 gallons, 24' Round
    Sand Filter
    Above Ground
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Re: Algae, Dirt, Sand??? Constant 2 year problem - pictures
    Looks like / sounds like dead algae.
    A slam is in order to eliminate it...
    Dolphin E10 Cleaning Robot.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Something to consider after the slam
    http://www.troublefreepool.com/conte...-a-sand-filter
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Casey's Avatar
    SW PA
    10,423
    Definitely looks like algae.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Looks just like mine. I had an algae outbreak awhile back and no amount of vacuuming seems to clean that mess up. It is too fine and goes through the sand in a sand filter. I am replacing my sand filter with a cartridge filter in hopes of minimizing that dead algae being recirculated back into the pool after cleanup.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Jul 2016
    clearlake
    1
    We have had this algae problem in Northern CAL. for the past couple of years..blaming it on our water co...hmmmm . ?
    Maybe global warming effects. El Nino`?? Our lake here is green with Algae to a point of hardly any water sports going
    on. Everyone blaming the new wineries and pot grows. Clearlake is a huge "living lake" but this really sucks.
    May 2016
    Fl
    18
    I am having a similar problem. My water levels are also in line and water is clear. I know you said you have been battling for a couple years. With that being said, with the water numbers in line what are the disadvantages of just sweeping it up and ignoring it?
    Has happened to me for the past 4 years as well, here in Rhode Island. I don't know if it is algae or pollen or a mixture of the two. Daily vacuuming/brushing etc... doesn't really combat it much. The first few weeks/months of the season are always fine and the water is crystal clear, then around the start of July and on I am constantly battling this issue and the green tint to the water.
    18' round AG vinyl | avg. 3'9" deep | ~7,600 gallons
    Hayward Pro Series Sand Filter, Model S166T | Hayward 1hp Pump
    Mar 2013
    Missouri
    39
    That picture looks like exactly what I have in my pool, with the same symptoms. I'm going to slam for mustard algae this weekend when I will be there to monitor my FC level. I've tried regular slam level and it slows it down but it always returns even after passing all 3 slam criteria. I'm hoping the mustard algae slam will get rid of this problem I've been struggling with since last year. I've tried about everything else as far as filtering, brushing, vacuuming and slamming and it still comes back within a day or two. You might try reading these two message posts for some more information and also do some research on mustard algae. Good luck and let us know how it comes out.
    very first algae problem...I think!!
    Questions and Help regarding Mustard Algae Slam
    The more I read and learn about mustard algae the more that I am convinced that that is what I have, especially when I was told that you can have it and still pass the OCLT test and it poofs up easily into a cloud when brushed. I didn't think it was algae when it wasn't losing any FC overnight.
    cruiser310
    25,000 gallon, 33'x54" Round AG Sharkline Matrix, 26" sand filter, 2 speed, 1 hp Pentair optiflo pump
