Thread: Remington Chlorine-Free Sun Shock Pool Purifier
    Jun 2016
    Katy
    25
    Any one had experience with this ionizer? Seems to have great reviews all over the place. However my concern is what does introducing copper into the pool do to plaster over time and to pool equipment especially the heater.
    Thanks
    Pool completed May 2014 (first time pool owner)
    Dimensions: 19X47, capacity 23,000 gallons
    Pentair Clear plus 420 cartridge filter/Rainbow inline chlorinator with Ozone
    Polaris 280 cleaner/Taylor K-2006 test kit
    30,414
    Re: Remington Chlorine-Free Sun Shock Pool Purifier
    You will find few fans of ANY ionizers on this forum. They all require chlorine anyway so TFP suggests you sanitize your pool with chlorine.
    JoyfulNoise's Avatar
    May 2015
    13,192
    Yes, copper at high enough levels will kill algae. The problem is, the required concentration of copper needed to act as an algaecide is very close to the concentration of copper that is unstable in pool water. Therefore any high chlorine or pH levels will likely cause copper scaling. On plaster that leads to staining that is very hard and expensive to remove. Once you build up too much copper in your water, you have to drain your pool, there is no other way to remove it. Copper does nothing to kill bacteria or viruses or oxidize bather waste. So you have to maintain a low chlorine residual in your pool water. It is very difficult to maintain low levels of FC consistently and homogeneously in a residential pool (circulation dead spots). Therefore you will likely not have proper sanitation levels most of the time.
    Leave the copper ions for keeping decorative water fountains clean and use as a root killer...don't put copper in your pool.
    Matt
