Results 1 to 12 of 12
Thread: Concerned about angle of Hayword Skimmer Intex rectangular pool
    Jun 2015
    Central Point Oregon
    20
    Cool Concerned about angle of Hayword Skimmer Intex rectangular pool
    Hello. This is my second pool and second skimmer install. I am concerned with the angle of the skimmer and wether or not it will function properly. I've only used three screws in the top mounting plate so far in case.......any feedback from folks who have this setup would be much appreciated.
    Thank you.
    [URL=http://s1079.photobucket.com/user/cpnursy/media/Mobile%20Uploads/2016-07/23308FE5-A45B-4366-AD5C-795A0B069190_zpszcnbycnz.jpg.html]
    Intex 9x18x54 pool, semi hard plumbed with Intex 3000 gph Sand Filter and Intex SWG, Hayward fittings, Intex Robot pool cleaner.
    Jun 2015
    20
    Re: Concerned about angle of Hayword Skimmer Intex rectangular pool
    Jul 2014
    Central New Jersey
    7
    Yeah, that won't work right at that angle.
    Jun 2015
    Stockholm, Sweden
    250
    The angle is no problem as long as you keep the waterlevel in the pool above halfway up the skimmer. Lower than that and it starts sucking air.
    Pics
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jul 2014
    Central New Jersey
    7
    Lisbeck's skimmer looks like it's mounted lower than yours, so I don't know how much "skimming" it will do with the water level above the opening. I guess it just looks weird to me at that angle.
    Jun 2015
    Stockholm, Sweden
    250
    Cant see Lisbek's pics, seems to be something wrong with the attachments. I recommend mounting as high as I have. Skimming works fine and there is no water depth loss at all. Waterlevel should be 2/3 up the skimmer for best performance.
    Jun 2015
    20
    Sorry about the photo issues. Can't seem to get them to load. Michelin I did check out your post while researching this site. I was concerned about going up into the reinforced area below the support strap but sounds like it hasn't caused you any issues. I will try moving it up a couple inches and see if that works. All of the sides are at that same pitch so changing the location won't make a difference. Thanks.
    Jun 2015
    Stockholm, Sweden
    250
    It is not really reinforced, it is just the weld of the liner to the strap. No issues whatsoever with cutting through the weld. I did put a patch under the skimmer as a precaution as you can see, but that was just for ease of mind, not really necessary. Good luck!
    KazzyK810's Avatar
    Jul 2016
    Davison, Michigan
    75
    Quote Originally Posted by Mickelin View Post
    Pics
    I really like the look of your skimmer! Is that a wide-mouth? Love how high it's mounted too. I only have a 48" deep pool and don't want to lose water depth, so have been hesitant to make the skimmer upgrade.
    Karan - 18 ft round x 48" high - Intex ultra-frame AGP, Intex 3/4 hp pump with 14" sand filter (SF70110), Hayward 900 Wanda the Whale cleaner, Intex LED water fountain.
    18ft Round Intex Ultra Frame in The Mitten
    Jun 2015
    Stockholm, Sweden
    250
    Thanks! Yes, it is a widemouth. I thought it looked better than the standard in a larger pool. The height is the same, so no difference in terms of water loss impact. Since you have a round pool, you dont need to worry about the angle issue. Mount as high as possible is my advice. Here are a couple of more pics from my ongoing deck build, soon to be finished.
    Jun 2015
    20
    That is awesome!!! I am thinking about a small deck on the end of the pool due to space and privacy.
    Jun 2015
    20
    Turns out my pump was underpowered. Upgraded to a 3000gph and finally the skimmer works like it should.
