Thread: Vit C on black algae?
    Jul 2016
    slidell
    58
    Re: bleach vs shock ??
    To manually rid the pool walls of black algae spores, does it make sense ( i was told this) to put Vitamin C tablets in a white sock and scrub the walls ?
    38,475
    Re: Vit C on black algae?
    No that doesn't make sense vitamin C is used to remove metal stains not black algae
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Welcome to TFP!
    More here about how to treat Black Algae
    Pool School - Black Algae
    Jul 2016
    slidell
    58
    thanks you gracious pool owner
    is scrubbing with tri chlor tablets in a sock the better option to remove black algae marks and are they inherently part of the gunite installation ?
    38,475
    Black algae is not a part of the gunite installation.
    While scrubbing with a trichlor tablet should work, it really depends on your pool's surface. If white, likely no issue, but if a colored plaster, the trichlor is very acidic so it could cause discoloration.
    DFW, TX
    24,509
    Better to follow instructions in the article I linked above.
