Thread: Liner staining
    Herwick's Avatar
    Apr 2016
    Ardmore, Ok
    49
    Liner staining
    Now that our water is clear we can see staining. There are 2 different ones that no amount of brushing seems to be getting rid of. The first and most troublesome, as it looks horrid, is a black ring around the pool. The second is a yellow stain on the floor of the shallow end.
    FC: 8
    CC: 0
    PH: 7.1
    TA: 97
    CYA: 25
    We got a lot of rain last night and had to do a partial drain this morning. Brought FC levels back up to 12 and gave my sock a few squeezes. We have been able to see the black stain for a little over a week, I think. The yellow stain we just noticed yesterday. Any ideas what they could be and how to fix them?
    1st time pool owner with 3 months of experience.
    25,000 gal, IG, vinyl, sand filter.
    ColorQ PRO 7 test kit
    Herwick's Avatar
    Apr 2016
    Ardmore, Ok
    49
    Re: Liner staining
    Here is the yellow staining. Its a lot more noticeable in person.
    And obviously the black staining.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Liner staining
    Here are a couple of tests you can do to see if the stains are organic or metal.
    Rub a trichlor pucks on the stain for a 1-5 minutes to see if it lightens the stain. If yes then the stain is organic. Raise FC to half or a little more of a shock value and brush daily. FC/CYA Chart.
    Rub a Vit C tablet on the stain for a few minutes up to several hours to see if it lightens the stain. If it does then the stain is metals. Pool School - Metals in the Water and Metal Stains
