Results 1 to 8 of 8
Thread: Help FC loss
    Sep 2015
    Los Angeles
    31
    Help FC loss
    Hey.
    due to chlorine consumption I assumed I had algae (hard to tell as I have a black-bottomed spa).
    it's an 1100 gallon spa with vanishing edge and overflow basin (300 gallon).
    current measurements are
    CYA 40
    shock FC 16
    Combined 1.0
    All other levels are balanced
    I'm losing 9 FC overnight even though the water is sparkling clear. I've been slamming since last sunday (5 days) Any thoughts on what's going on?
    thanks
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Help FC loss
    What's the temp on the spa?
    9 FC is unacceptable loss overnight, even in a very hot spa. You must still have some organics in the spa. When did you refill the spa last? Have you ever performed a spa flush on the entire system with a product such as Ahh-some?
    Isolated Spa - 345 Gallons
    Sep 2015
    Los Angeles
    31
    Re: Help FC loss
    Quote Originally Posted by JVTrain View Post
    I refilled a month ago.
    I've never used those products, the spa is only a year old.
    Is it okay to use ahhsome or yuk with an inground spa? Also is there one you recommend?
    thanks!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Help FC loss
    Ahh-some jetted tub cleaner is the recommended product.
    Is it a gunite spa? Please fill out your signature so that we can better help you. More here on what to put in your signature and how to do it, Pool School - Read This BEFORE You Post
    Sep 2015
    Los Angeles
    31
    Re: Help FC loss
    Quote Originally Posted by pooldv View Post
    It is gunite, does that make a difference?
    added extra info to sig
    1100 gallon gunite IG spa with vanishing edge and 300 gallon overflow basin. Cartridge filter, hayward variable speed pump, finished 11/15/15, Taylor kit,
    DFW, TX
    24,485
    Re: Help FC loss
    I don't know if the Ahh-some is designed to go through a pool filter and vice versa. I would be inclined to clean the filter and perform a SLAM
    Sep 2015
    Los Angeles
    31
    Re: Help FC loss
    I'll clean the filter tom. Do I need to soak the cartridges in anything or just wash them out the hose?
    Really appreciate the help!
    D
    DFW, TX
    24,485
    Re: Help FC loss
    Probably no need since it is fairly new.
    More here on cleaning
    Pool School - Maintenance and Cleaning of Pool Filters.
    And here,
    Re: How to clean a cartridge filter
