Thread: Help please
    Sep 2015
    Los Angeles
    31
    Help please
    Hey.
    due to chlorine consumption I assumed I had algae (hard to tell as I have a black-bottomed spa).
    it's an 1100 gallon spa with vanishing edge and overflow basin (300 gallon).
    current measurements are
    CYA 40
    shock FC 16
    Combined 1.0
    All other levels are balanced
    I'm losing 9 FC overnight even though the water is sparkling clear. Any thoughts on what's going on?
    thanks
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    439
    Re: Help please
    Your CC is over 0.5 and if you are losing 9ppm FC, you definitely have something going on. If it were a pool, I'd say brush the walls and SLAM it. However I think there are different guidelines for spas. In terms of SLAM levels, maintaining 16ppm FC only takes between 2-3 cups, depending on strength of your chlorinating liquid.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    May 2016
    Orange, TX
    65
    Re: Help please
    I had clear water but was losing a bunch of FC each day, just like you were. Happened just this week.
    You mention all other levels are balanced, so I'll assume the pH is not over 7.8 ish. I say that because this week my pool had no FC in it, added more than enough, next day, same problem. My pH was 8.2, high pH reduces effectiveness of FC. I thought I had algae, but correcting pH back to 7.2 - 7.4 allowed my FC to hold.
    I will agree with above poster, 1.0CC means that chlorine is chewing on something...
    Are your results derived from one of the test kits we use here? Those results can be trusted, strips not so much. Pool store testing is sometimes good, sometimes not. I basically just trust my kit to get me the info I need.
    Lee Mims - Orange, TX, 25400 gallon In-Ground Plaster Pool
    Hayward Cartridge Filter, Hayward Chlorine Feeder, Century 1081 2-Speed Pool & Spa Pump, Hayward H350FDN (350k BTU) Natural Gas Water Heater, Paramount O3 Ozone, Hayward Super II Pump for Waterfall, Aqualink RS System w/ Remote (Jandy), Taylor K-2006 Kit
    Sep 2015
    Los Angeles
    31
    Re: Help please
    Quote Originally Posted by fajitas21 View Post
    Yup. I'm using the taylor kit. PH was 7.1-7.2 when I started slamming last sunday.
