Thread: Question
    Jun 2014
    Little Ferry, NJ
    16
    Question
    Hello all,
    Question: On my CYA test, if I can no longer see the black dot on the tube at the 25 mark. Do I need to add 38oz by volume of stabilizer as indicated on PoolMath to reach the goal of 40?
    18000 gallons - IG
    Concrete
    DE
    Heyward C48L2N134B1 1.5HP Pump
    15+ years since built date
    Aug 2013
    Otsego, MN
    79
    Re: Question
    Quote Originally Posted by BugginOuT View Post
    Hello all,
    Usually, CYA results are rounded up to the next "10" number, so 25 would be read as 30.
    Better to under-add and have to add more, than over add and get CYA too high.
    Pool/Equipment: 20'x52" round Intex Ultra Frame AGP (~8,800 gallons)--Intex SWCG (CG-28669, 15K gallon model)--Intex Sand Filter Pump (SF60110, 16", 120lbs sand, 3K gph)--Hayward SP1091LX Through-Wall Skimmer--Hard Plumbing--Taylor K-1766 Salt Test Kit--TF-100 Test Kit
    Jun 2014
    Little Ferry, NJ
    16
    Re: Question
    gotcha. Thanks.
    18000 gallons - IG
    Concrete
    DE
