Thread: Pool just finished, and we have a leak!
    May 2016
    Prosper/TX
    9
    Our pool was just finished a few days ago. They started running the pump and after a couple of days we have this random stream of water coming from a spot between the rock and stone. We have a water feature along the back wall, and this is about 3 feet away from it.
    How bad is this? And, how much do you think they will have to tear it up to fix it?
    ~Rene
    17/28 geometric, 7x7 raised spa, Tahoe Blue Quartzscapes, 1200 sq ft paver deck (Belgard/Urbana Stone/Danville Beige), Sheer Descent 24", Jandy E Pump 2.0 HP Var Speed, Jdy Heater 400 BTU JXI Natural Gas, Jandy 460 Cartridge Filter
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Re: Pool just finished, and we have a leak!
    So sorry to see this. That will need to be fixed for sure.
    Can you post a picture from father away? It's impossible to tell where that is on the pool, or how they might attempt repairs.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2016
    Prosper/TX
    9
    Here is a bigger picture.
    ~Rene
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    I would guess that the back wall contains a pressurized line running from left to right into the spa (appears a jet is straight in line with the back wall). All depends on how the elevated portion of the back wall is constructed. Likely is all rebar and shotcrete all the way from the bottom of pool up to the top cap, encapsulating the line.
    I think the builder can provide the schematic plan and get an inspection camera from the spa jet back to the suspected leak area and limit the amount of demo and repair.
    Good luck with this one, but it should be easy.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    May 2016
    Prosper/TX
    9
    Thank you-I'm hoping it's an easy (ish) fix!
    ~Rene
