Results 1 to 10 of 10
Thread: water leaks from lid of pump
    Jun 2016
    Israel
    23
    Pump is now pumping. But
    When pump is off. Water leaks from top of he pump.
    SummerEscape Vinyl round. 366x122m
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    Re: water leaks from lid of pump
    Quote Originally Posted by chanansiegel View Post
    Can you please tell us what type of pump you are working with and a picture would be helpful. Is the pump leaking when running and/or when idle (or both)? Thank you.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jun 2016
    Israel
    23
    Summer wave rx1000-s. Only leaks when pump is off
    Catanzaro's Avatar
    Jul 2014
    2,255
    All Summer Backyard Products from SummerBackyard.com
    Above you will find a link to the parts, etc. I believe this is your pump. Chances are that your gaskets have deteriorated and you would need to replace them. Is there a gasket where you see the leak?
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    If it's coming from under the lid, you may need a new gasket. Do you get bubbles in the basket when the pump is running?
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    Jun 2016
    Israel
    23
    No bubbles when pump is on.
    Gasket is present only two months old.
    When pump is turned off large rush of water goes back into the pool after pump is turned back on. When on very little water in pump. when off pump basket is full of water and excess water leaks from top
    Catanzaro's Avatar
    Jul 2014
    2,255
    Is there a gasket where the leak is with pump off?
    Jun 2016
    Israel
    23
    Yes their is a thin gasket.
    Looks something like this. Replacement Motor Seal Gasket for Summer Waves SFX600 SFX1000 Filter Pumps from SummerBackyard.com | Free Shipping
    It inside the slide, in the grooves
    Catanzaro's Avatar
    Jul 2014
    2,255
    You may want to disassemble the pump, add lube to the gasket and carefully put everything back together. Inspect the gasket as well. If everything appears normal and you put everything back and there is still a leak, you may want to place a silicone designed for bathtubs. It can easily be removed. This should do the trick in sealing everything up. Might as well pick up everything at the same time and then you can always return what you do not need. This would be your best bet. If the gasket is bad, then you will have to order a new one.
    Jun 2016
    Israel
    23
    It might appear if the water is below the return valve in the pool. That it does no leak..
    But more testing is needed
