Thread: New to all this....but learning
    Jul 2016
    nebraska
    1
    Hi all,
    I just put up a 16 x 24 above ground pool.
    Got talked into using BAQUACIL by the pool store...
    Havent had a chance to see the results yet.
    has anyone else used this product and what kind of opinions are out there?
    It does seem pricey and I probably will go to Chlorine once I learn the basics.......
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Re: New to all this....but learning
    Have you put it in the pool yet?
    We have a whole forum just for converting from Baquacil to chlorine. The main reason is $$ and over time is causes problems.
    If you have not put it in don't. Come back and let us know where you are at as far as the pool and stuff in it.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    Here is the Baquacil Forum, Baquacil - Use and Conversion
