Results 1 to 8 of 8
Thread: Relationship between CYA and pH
    Jul 2016
    Sacramento, CA
    5
    I have a 10,000 gal in-ground vinyl pool. Current CYA is 55-60 which I know you say is high. Pool supply company - decent folks who don't try to sell me things - think this level is ok. What concerns me is each week I need to add a pint of acid in order to lower pH to correct level. Am not using a stabilizer, last year had an issue with super high CYA and "pink bloom" algae. I can drain some of the pool but don't want to waste the water unless necessary.
    Current chlorine demand is 2 gal per week liquid chlorine.
    So question is does CYA affect pH? Ie is need for continuous addition of acid due to current level of CYA?
    Appreciate all suggestions and information.
    Novastar
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Relationship between CYA and pH
    Welcome to TFP
    You CYA has nothing to do with PH, it can when you first put in CYA, it may drop you PH a little... congrats on lowering your CYA
    PH rises from, waterfalls, returns hitting the top of the water and creating ripples, raised spa's, SWG's... anytime air can get into your water and break the surface can raise PH.. If you bring your TA down it will help you PH not raise as fast..
    Pool School - Lower Total Alkalinity
    I hope this helps
    domct203's Avatar
    Jun 2015
    CT
    3,584
    Quote Originally Posted by Novastar View Post
    Welcome!
    How do you test the water, and how often?
    How do you normally chlorinate, and what is your daily FC target?
    A CYA level of 60 may not be all that high if your pool is in direct sun all day long.
    For a CYA of 60ppm your FC target is 7ppm, and the minimum you should ever let it go is 5ppm.
    Pool School - Chlorine / CYA Chart
    Two gallons of 10% chlorine will add 20ppm, or about 2.85ppm average per day for 7 days, not bad at all for a pool that is being used often and left uncovered.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jul 2016
    Sacramento, CA
    5
    Not sure how to lower total alkalinity. But perhaps I have a partial answer - my backyard sprinklers hit the pool water whenever they go on.. Wonder if this may be it.
    Novastar
    Jul 2016
    Sacramento, CA
    5
    I test about every 3 days. As I responded to other "helper" not sure how to test for FC. Or how I figure out ppm.
    I use the simple little Poolmaster 5 way test kit. With the water ampler and drops of solution. Maybe I need a different kit?
    Thanks so much, look forward to more education.
    Novastar
    38,284
    Sounds like you need to invest in one of the Recommended Test Kits
    Jul 2016
    Sacramento, CA
    5
    I'll check them out. Thanks.
    Novastar
    domct203's Avatar
    Jun 2015
    CT
    3,584
    Have a read here:
    and here:
    and here:
    Pool School - PoolMath
    Dom
    Dom - TFP Guide
