Results 1 to 15 of 15
Thread: The green monster....
    joshm1970's Avatar
    Jul 2016
    Oklahoma
    8
    Tested the cya and FC this eve after receiving my tf-100 today (lightning quick shipment). Both were at 0 and the pool is green. Question is do I need to get the pool cleared up a bit before adding the stabilizer to bring the cya up? I've added 8.25% bleach to get the FC up to 12ppm trying to get a jump on the SLAM.
    18'x48" Intex AG around 7,600 gal, Intex 3,000gph sand filter pump, Hayward thru wall skimmer, TF-100 test kit
    38,299
    Re: The green monster....
    Add enough stabilizer to get too about 30ppm and then SLAM away. Make sure you lower the pH before raising the FC.
    joshm1970's Avatar
    Jul 2016
    Oklahoma
    8
    Cool, is the liquid or powder stabilizer better? pH was at 7.5 is that sufficient?
    Aug 2014
    Northern IL
    4,615
    You may want to look at this thread and check that you don't have an ammonia issue:
    Dealing with Ammonia
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Granular stabilizer is fine. More here on adding CYA and chems, Pool School - Recommended Pool Chemicals
    7.2 is the preferred PH for a SLAM. More here, SLAM
    joshm1970's Avatar
    Jul 2016
    Oklahoma
    8
    Done, my FC loss was only 4ppm over a 2 hour period, so I'm taking that as less than a 50% loss in a 10 minute period? So bring the cya up to 30ppm?
    DFW, TX
    24,497
    Quote Originally Posted by joshm1970 View Post
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Yes.
    Aug 2014
    Northern IL
    4,615
    Yup! Thank goodness!
    From now on, check your CYA during the day and only in bright sunlight.
    joshm1970's Avatar
    Jul 2016
    Oklahoma
    8
    Ok, got the liquid stabilizer. Is there a certain FC level to be at to bring the cya up?
    38,299
    You have it backward.
    Set the CYA level and then use that to determine the FC level required according to the FC/CYA Chart
    joshm1970's Avatar
    Jul 2016
    Oklahoma
    8
    I've seen that and know the system, but I've had the FC level raised to 12 since last night when there was no cya present to get a head start on the SLAM. I'll add the stabilizer to get my cya up to 30 or so. My question was can I add the stabilizer to get the cya up, no matter what the FC level is right now. Then adjust the FC according to the cya level after testing.
    38,299
    Yes, the FC level does not impact the ability to add CYA.
    joshm1970's Avatar
    Jul 2016
    Oklahoma
    8
    Thanks, all this is so new to me! Lol!
    Going from chlorine tablets and shock powder and whatever else you can buy at Walmart. I truly appreciate all the help, and my pool has gone from nasty green yesterday to off great/blue today! I have a feeling I'm on my way to clear water!!
    joshm1970's Avatar
    Jul 2016
    Oklahoma
    8
    Also, how long after adding the liquid stabilizer should I test the cya? Just pour it around the edge of the pool?
    38,299
    Likely the liquid stabilizer should show up on the test as soon as it has circulated (a few hours). But just use PoolMath to calculate how much you need to add for a given target and assume you are at that right away.
    Recommended Pool Chemicals should explain how to add everything (I think liquid stabilizer is covered there). Should be able to just pour it in front of a return jet to help it mix.
