Results 1 to 11 of 11
Thread: Crape Myrtles, is there a better solution for their flower stains? Did I panic?
    Jul 2015
    Jacksonville Florida
    18
    I had just finished brushing and vacuuming the pool after yard work and a thunderstorm came up and blew Crape Myrtles flowers by the pound into the pool, I skimmed the surface within an hour and removed most, but then I noticed on the bottom in a couple corners of the shallow end quite a bit of staining from the debris. I immediately vacuumed and brushed again with no success, I panicked and dumped 8 cups chlorine in and went to scrubbing again, well with a lot of elbow grease I think I got the stains gone.
    I started reading on the forum about these debris makers and I found a lot of posts to cut them down, but I found an older one that said the normal chlorine levels will take care of them but just need a little time to work, did i jump the gun and panic? Would the chlorine normal levels have removed the stains by say the next morning?
    Would appreciate it if any of you more knowledgable pool owners know the answer, we just put this fiberglass pool in last year and I am trying to keep the stains to a minimum. And I did check with the landscape boss, no more tree removal is allowed (I removed 6 in the back yard), not even
    Crape Myrtles the have become trees on the other side of the house.
    Appreciate your thoughts. Keith
    Sun Pools fiberglass Rio, 11,600 gallons, Installed 11/2015
    Hayward 3/4 hp super pump, Hayward 150 cartridge filter
    Taylor K-2006 test kit with speed stir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Crape Myrtles, is there a better solution for their flower stains? Did I panic?
    Probably not by the next morning. Raising FC A few ppm above target and brushing will get rid of the stains. Just some regular brushing, not scrubbing.
    Jul 2015
    18
    pooldv, Thanks for the advice, the pool looked real good this morning, I will remember next time and just let the chemicals do the hard work.
    Again, Thanks Keith
    Aug 2014
    Houston tx
    2,525
    We also have a crepe myrtle that drops a bunch of debris into the pool. I try to hand skim and the pool skimmers do a pretty good job of getting the rest. I have to replace the skimmer nets (thank goodness for hairnets!) about every other day. We've just learned to live with it, since we don't want to get rid of it. But, we haven't had any staining.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jul 2015
    18
    Marla, I haven't tried any hair nets yet, I may give them a try and see what happens. The crape myrtles grow every where here and are pretty in bloom so i will just have to learn to live with them. Keith
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Hey, neighbor. I'm not sure the dimensions on your pool, but we have a neighbor that is now covering his pool with the enclosure netting on a roll (like a solar cover but basically aluminum mesh netting). He's not getting any debris and no side effects of using a true cover in our summer heat.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Aug 2014
    Houston tx
    2,525
    Marla
    Jul 2015
    18
    Quote Originally Posted by txnole View Post
    Hey right back neighbor. I am curious about this cover, I have a shade sail over my pool and wanting to maybe go to two sails. I use them of course to beat the sun, been able to keep my water temp around 73 with sail and aerating one deck jet during the night, but with our many afternoon thunderstorms the sail has to come down in the afternoon quite often. Maybe your neighbors mesh would beat two problems, and keep the pool clean, My pool is rectangle 14 x 28.
    Appreciate any more info on the mesh if you can.
    Thanks, Keith
    Quote Originally Posted by Marlahoutex View Post
    Marla, Thanks, got them on order, appreciate the link, Keith
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    His setup is very DIY... Aluminum screening on a roll, that roll is placed on a pool cover roller... He rolls out the screening all the way over the pool and then anchors it on the far end with tent stakes. Simple. I'll get a pic.
    Jul 2015
    18
    txnole
    Appreciate it, the pic's will be helpful, I am wondering if the screen could serve a dual purpose of keeping the pool cleaner and water from heating up, I will wait for the pic's.
    Keith
    Jul 2014
    Hope Mills, NC
    569
    A chainsaw taken to those obnoxious weeds. That tree is an invasive species and needs to be controlled.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
