Results 1 to 7 of 7
Thread: TA at 230! How do I lower it???
    Jun 2015
    Clinton, Utah
    57
    Hi! This is our second year using the TFP method. We have a round Coleman vinyl pool that I believe is 16 feet wide. I know that it holds 5,140 gallons of water. I got my new test kit and my levels were as follows:
    FC- 1.5 ( SWG and ran for a longer cycle tonight as we had a breaker blow mid day today)
    CC- .5
    TA- 230! I've never had that high of a reading?!
    PH- 7.8
    TC- 1
    CYA- 60 (added cya approx. 3 or 4 days ago)
    What do I do about my TA?! Pool cal says to lower ph with MA and aerate the pool, but I don't know exactly what the means??
    TIA!
    Coleman 16'x48" AGP, Pump is what came with the pool 1,000 gallon pump I believe with Cartridge, SWG Intex brand Krystal Clear
    First Year Pool Owners
    38,248
    Re: TA at 230! How do I lower it???
    TA is very low priority, in fact you could nearly ignore it. Just keep the pH in range and the TA will slowly drop and stabilize.
    You should be more worried about your FC being too low.
    Jun 2015
    Clinton, Utah
    57
    Okay thank you! I'll add some bleach tomorrow if the longer run cycle doesn't take care of it! I can now go to bed and stop working about the dang pool hahhaa! Thanks again!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Did you wipe the bottle tip on a damp cloth between drops? If not that can cause a false high reading on TA. Check the extended directions here for more details, Pool School - Extended Test Kit Directions
    Jun 2015
    Clinton, Utah
    57
    I did yes. I will retest this weekend just to see, but I'm much less worried about it now!
    Mar 2016
    Phoenix, AZ
    48
    Why does that make a difference? I have had a TA reading of 120-130 recently and I am in the process of lowering it to 90 or so.
    I am referring to the wiping of the bottle for clarification.
    10,000 gallon, inground, pebblesheen, sand filter, TF-100 testing kit, Pentair Rebel
    38,248
    There is a static build up in the very fresh reagent in the TF-100. It goes away after a few tests. Just be sure you have good normal drops.
