Thread: Bugs, branches and other bits!
    Jul 2016
    Northern California
    2
    Hello all, its been about 3 weeks and my pool is still crystal clear! But my issue is that there's all manner of tiny things floating around the water! How should I deal with this? I manually skim and I run the pump for 2 hours daily when I treat the water. I also cover the pool when not in use.
    The bugs are driving me nuts! There always seems to be more after I skim!
    10' Intex Easy Set, 1018 gal. 300hp pump? Northern California.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Re: Bugs, branches and other bits!
    The goals in determining pump run time are a) keeping water clear, b) keeping water skimmed and c) if you have a SWG, to create enough chlorine.
    You are not running it long enough to keep it skimmed so you should run it longer.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Major_in_MS's Avatar
    Jul 2016
    Florence, MS
    94
    What kind of test kit do you have? If you have one of the two recommended test kits, Taylor K2006 or TF-100 test kit by http://tftestkits.net/splash-page.html then post up a set of results and we will try to help you. If you don't have one of these two test kits, then please consider ordering one and start reading from the Pool School link at the top of this page while you wait for your test kit. Also, I would get some bleach into that water and run your pump more. Without knowing your CYA level and chlorine level I can't say how much bleach to add, but I would start with about 8 to 12 oz per day till your kit arrives.
    24,200 gal., IG vinyl, 18' x 36' rectangular, average depth 5'. K-2006C
    Jandy SFTM22 sand filter, 1.65 HP PureLine VS Pump, Doheny's Discovery Robot.
    One skimmer, one main drain, two eyeball jets, and one return from the booster pump.
    One wife of 28 years (schoolteacher, first grade), four kids (ages 16,18,19, and 21).
    I work night shift (Pediatric RN) so most of my posts will be during the night.
    wjr75's Avatar
    Jun 2013
    IL
    836
    We have our yard sprayed every month by Mosquito Squad and don't have any problems with those little nats.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
