Thread: Air in pump basket
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Air in pump basket
    Split off of Leak on suction side. Please ask questions in your own topic. JasonLion
    I think I have a similar problem. when my pressure rasies approx 5psi, I get some bubbles in the pump basket, and air bubbles out of one return jet. I did read something that said just put pvc glue near the connections coming into the pump? does this sound like the same issue and a viable solution? I've never noticed hissing.
    Re: Air in pump basket
    You need to figure out where the leak is before you can try fixing it with glue. By far the most likely place is the O-ring around the lid to the pump strainer basket. Make sure it is clean and free of nicks and cuts and well lubricated.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by reebok
    When pressure rises in a filter, the suction should decrease and bubbles should also decrease. So what you are seeing is opposite of what I would expect. Is the 5 PSI rise due to a dirty filter or something else?
    Mark
