Thread: Spill over spa rising after 6 years
    Oct 2010
    michigan
    284
    TRIAC 90 SPILL OVER SPA, PLUMBED, WHITE - Northeastern Swimming Pool Distributors
    The spa i have that over flows into the pool.
    Over the coarse of 6 years its unlevel and rising up, which doesnt make sense?
    How can the spa raise up?
    Raised up about 2 inches on 1 side.
    I do live in michigan, so maybe doing it in the winter?
    I looked at pictures from the first year we got the pool, and its defiantly raising up on 1 side.
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Spill over spa rising after 6 years
    frost heave is the only thing I can think of, unless you have really strong moles digging mounds under it..
    Do you know when it was dug was it dug out under the frost line and then filled with rock/gravel back to level, I am not exactly sure how they do it...
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    We have black clay here that can expand and contract a lot based on moisture levels. Our whole pool raised about 3/8" due to uneven moisture levels in the soil. Fortunately, managing soil moisture levels has gotten things under better control since then.
