Thread: Travertine Decking Snafu & Question
    Sep 2015
    Tucson, Arizona
    86
    We contracted with a sub to install "4 Piece French Design Scabos Travertine" decking. Install happened last week while we were out of town. There are a number of issues that I am going to meet with the sub about, but there is one issue I am hoping to hear your collective wisdom on: instead of installing the travertine in a repeating French pattern, the installer placed pavers randomly, so there is no pattern whatsoever. I am weighing how much this bothers me, but my question is beyond aesthetics, what are some practical reasons to insist on a "French" or Verseille pattern over just random placement of pavers? There are some spots where there are continuous grout/joint lines that would be eliminated if the sub had followed a French pattern, and I think that goes beyond aesthetics. Others? Thanks in advance...
    Owner Build. 32x16, with 6x8 raised spa. Broke ground April 1, 2016, swimming July 18. Pentair Intelliflo VS + Whisperflo for Water features; Clean & Clear Filter 420; Master Temp Heater 400k BTU; Intellibrite 120V pool and spa lights; Regular ol' plaster.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,234
    Re: Travertine Decking Snafu & Question
    Sorry to hear your situation is all fouled up.
    There's no structural or practical reason why grout lines should either line up or not line up.
    If there are separate concrete structures under the stone, you need to align the pavers to the joint, and usually allow for contraction or movement with options other than grout. Other than that, paver patterns are pretty much just aesthetics.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
