Results 1 to 10 of 10
Thread: Cartridge cleaning questions
    OutWest's Avatar
    Jul 2016
    El Dorado County, CA
    35
    I am going to be more vigilant in cleaning the pool cartridges. Honest, I really am. At least that is the plan.
    I'm getting a big trash can that will hold all four of my cartridges so I can soak them in TSP. Already got the latter. I'm going to get another pressure hose nozzle if I can't find the one I already have. (For $3, it doesn't hurt to have two.) my questions for experienced cleaners of cartridges:
    Where do you dump out the wash water containing TSP? Pretty strong stuff and I don't want it near my plants...
    How do you know when all the cleaning solution is out of the cartridge material? I don't want it washing I to my pool water.
    What do you think of the Blaster 2000 gizmo that purports to clean cartridges? It's pricey but I love things that do things for me. Not sure if it's worth the $$$ though.
    8,900 gal in-ground gunite lap pool; self-cleaning Jandy 1.5 HP Pro Series E-pump system; Jandy CV340 pool/spa filter with four cartridges; Propane heater (rarely used); motorized pool cover.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Cartridge cleaning questions
    I like this doodad, Filter Flosser | Filter Flosser Cartridge Cleaning Tool
    I dump mine right into the grass/weeds, it doesn't kill either one.
    I've never had any issue with the filters not being rinsed enough. I think by the time the junk is washed off the TSP is long gone.
    Good luck on your mission, mine is to brush more.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    What is TSP? And will it work on robot cartridge filters?
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by kywildcats View Post
    Tri Sodium Phosphate. It's a mild detergent that has generally fallen out of favor since the phosphate gets into lakes, rivers, and oceans and causes eutrophication. In the small does you would use to clean your cartridges there is negligible health risk, since this product is a food additive in Europe and "generally recognized as safe" in the USA.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    OutWest's Avatar
    Jul 2016
    35
    Quote Originally Posted by pooldv View Post
    Does the flosser have much water pressure since the water gets spread between multiple openings?
    Quote Originally Posted by OutWest View Post
    That's essentially the point, it provides increased pressure because although there are more openings they are very small.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    DFW, TX
    24,514
    Yes, it works well, the pressure is good.
    OutWest's Avatar
    Jul 2016
    35
    OK, so yesterday I bought two 32 gallon plastic garbage tubs (on wheels). I disassembled R2D2, the cartridge container, today. The carts were once again filthy, but not as bad as last time. I brushed off as much as the dirt and debris as I could, put them into the garbage cans with detergent, and am going to let them "cook"/soak on the patio for a good long while. Tomorrow morning I'll use my brand new pressure nozzle and hose them down. Fingers crossed that this will help! Oh, and I also ordered a blast master (?) max pool vacuum. Should be here middle of next week. I am determined to whip my pool into shape.
    Sorry for the sideways photo. Tried to delete it and re-upload but did not see how to do that.
    DFW, TX
    24,514
    Sounds like a good plan!
    Ukie's Avatar
    May 2012
    Export, PA
    83
    I've tried using my electrical power washer (yeah, it doesn't have crazy PSIs) to clean my cartridges and I LOVE results. I was impressed how much gunk I was able to wash out from between filter pleats. I have Aquacomb Amazon.com : Mi-Way Aquacomb Pool Filter Cartridge Spray Cleaner Tool : Swimming Pool Maintenance Kits : Patio, Lawn Garden and used it with great results when my filters where newer. This is 3rd season for my filters, and they needed what I call "a deep cleaning" and power wash was a right tool for it!
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
