Results 1 to 12 of 12
Thread: Adding Salt to non-SWG pool
    Jul 2016
    Saint Joseph, MO
    45
    I read the brief paragraph about Salt in Pool School, and I like the idea, but not sure why, so I have a few further questions:
    > When/why would I want/need to add some salt to an otherwise fine pool?
    > How much salt?
    > Would adding ^ that much salt change any other pool chemical numbers for non-SWG pool?
    > Will the salt level stay there, kind of like CYA, until water is replaced?
    THanks!
    CHAD
    24' Above Ground 46.5" deep, 13,147 gal
    Hayward E-Series 25GPM/m2
    Sand 200 lbs
    Hayward Power-Flo LX 1.5hp
    Taylor K2006
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Adding Salt to non-SWG pool
    Salt is added for improved water feel. It is better on skin and eyes because we are salty. 2000 ppm is the recommended starting place. Saltwater pools have 3500 ppm, tears are 9000 ppm and the ocean is 35,000 ppm. No change to any other chemistry. Yes, salt does not evaporate and hangs out in the pool same as CYA and CH.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Salt is added to a SWG pool to improve the "feel" of the water. Kind of like softened tap water feels better to shower in than unsoftened water.
    I would start with adding 1500 ppm or so to see if you notice the difference. If you've been using bleach already, you likely have some salt in the pool. You should get test strips for salt at a minimum to check the level. One of the few tests that strips are acceptable. Not as good as drop test, but acceptable.
    The salt will stay in the water unless you drain, just like CYA. It will not change any other recommended levels or alter your FC demand, unless the salt was contaminated with organics some how.
    Isolated Spa - 345 Gallons
    DFW, TX
    24,497
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by pooldv View Post
    No you!
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    So salt won't affect ch? People around here use salt to soften water.
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    DFW, TX
    24,497
    That is a different process. No, salt will have no impact the on CH level in the pool.
    Jul 2016
    Saint Joseph, MO
    45
    OK, I may try this out. You think back flushing will harm grass?
    CHAD
    Sand 200 lbs
    Taylor K2006
    DFW, TX
    24,497
    No, I don't. Our pool overflow goes into the yard and hasn't killed grass/weeds there at all in 4 years. No trouble around the equipment pad with draining the cartridge filters, cleaning leaf basket, etc.
    Oct 2014
    San Antonio, TX
    449
    A water softener has a tank with small rubber beads that collect the calcium from the water as it passes through the tank. A salt brine is flushed through the tank to wash out the collect calcium during a weekly/metered regen. The water from the regen is extremely salty - probably higher ppm than the ocean. That will kill almost anything.
    Free form 17X30. 14,500 Gal. Pentair sand filter and 1.5 hp pump. Aqua-Rite SWCG. TF-100 Test Kit w/Speed Stir
    Jul 2016
    Saint Joseph, MO
    45
    Quote Originally Posted by JVTrain View Post
    Is 1500 about the minimum to notice benefits, would you say? That's like four 40 pound bags. Also, what are the exact product names that are OK to add, like from Lowe's or Wal-mart.
    These are OK?
    Shop Diamond Crystal 40-lbs Salt Solar Crystals at Lowes.com
    CHAD
    Sand 200 lbs
    Taylor K2006
    DFW, TX
    24,497
    Yes, that is fine. I think pool salt is a little cheaper at Lowe's. Any 99.5 or more pure salt is ok. Yes, 1500 to 2000 is the recommended starting point.
