Thread: Which one? Input requested
    OutWest's Avatar
    Jul 2016
    El Dorado County, CA
    35
    I've been having a hard time getting all the dirt out of my pool. I purchased an AquaBroom a while back but it wasn't up to the job. I have dirt and silt on the bottom, not leaves. After reading comments and reviews on here I've decided to try again with a handheld. Which of these would you recommend? Are they vastly different? Once I settle on a product I'm going hunting for the best price.
    Pool Blaster Max HD
    Amazon.com : Pool Blaster Max HD Manual Pool Vacuum Cleaner : Swimming Pool Handheld Vacuums : Patio, Lawn Garden
    Pool Blaster CG Max
    Amazon.com : Water Tech POOLBUSTERCG Pool Blaster, Max CG : Swimming Pool Handheld Vacuums : Patio, Lawn Garden
    Thanks in advance for your input.
    8,900 gal in-ground gunite lap pool; self-cleaning Jandy 1.5 HP Pro Series E-pump system; Jandy CV340 pool/spa filter with four cartridges; Propane heater (rarely used); motorized pool cover.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Which one? Input requested
    seems the one with the biggest battery and easiest to clean wins
    OutWest's Avatar
    Jul 2016
    35
    Quote Originally Posted by cowboycasey View Post
    That would have been my thought too. Thanks for chiming in.
    OutWest's Avatar
    Jul 2016
    35
    So I decided on the Pool Blaster Max CG. it should arrive in a couple days. Am hoping that this, along with my cartridge cleaning efforts, will whip the pool into shape. Fingers crossed!
