Thread: How long do I keep the pool pump running?
    Jul 2016
    las vegas, nevada
    16
    Post How long do I keep the pool pump running?
    New pool owner. I will probably have many questions. One that I am hearing different opinions about is how long do I keep the pool pump running for each day. I live in Las Vegas. I heard an hour for every 10 degrees. Is that correct? Thanks!
    20k plaster pool, Century B130 pump, Pentair cartridge filter, Jandy JXI pool & spa heater, Paramount in-floor pool cleaning system, TF-100 test kit
    Jun 2014
    15,008
    Re: How long do I keep the pool pump running?
    Hello again Eddie. No, that's not really a good estimate, nor is water turn-over rate which is also very popular. You have a couple main considerations when it comes to pump run time - mixing chemicals and surface debris. As long as you can run the pump long enough to do those things while maintaining overall good filtration & water clarity, you are good. Folks who are new to pools might start their pump run time around 8-10 hours, then adjust it back to about 7, then 6, etc until they find a spot their pool is happy with. You don't have a SWG, but your in-floor cleaning may have a suggestion or two as well for efficiency.
    There is some more info on the TFP Pool School - Determine Pump Run Time page.
    Jan 2014
    Buckeye AZ
    807
    i went down to 4 hours for the winter and decided to just leave it there for the summer. No problems yet. Pool is a little dirtier when we go to swim, but that's because I run the pool at night when the pump won't be as hot. The "total" cleanliness of the pool is the same (it's not been accumulating dirt).
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    I run mine a bit more than previous years because we're getting a lot of surface debris this year (lots of trees, construction in the area, etc).
    I keep my SWG on a very low setting which compensates for the long run time also.
    Jul 2016
    las vegas, nevada
    16
    Great reading, great advice! I am going to start playing around with the run times and see what happens. I believe I have the chlorine and PH levels stabilized. No algae right now. After I do complete testing this week I will report back on my levels. Thanks everyone!
