Thread: help with Pentair High Flow Valve
    Jul 2016
    merrill, wi
    1
    I have an Pentair Hi-Flow Valve. Does anyone know how I would be able to replace the seal-diverter and remove the seal that has been glued to the plastic? Is there a chemical that I can apply that will dissolve or loosen up the rubber that has been glued inside of the unit? Thank you for any responses and assistance.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Re: help with Pentair High Flow Valve
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
