Results 1 to 10 of 10
Thread: Very Noisy Pump
    Jun 2016
    Regina, SK
    13
    Very Noisy Pump
    Hello, we went on vacation for a week and came back to a very noisy pump. It is still working but extremely load. Water level was low, so raised that up. Could that be the cause? Any other troubleshooting ideas or time for a new pump?
    Thanks
    Jun 2014
    15,130
    Re: Very Noisy Pump
    When the water level was low, does that also mean the pump was running "dry" (no water inside)? My initial thought is that the pump may have overheated and/or the bearings inside are showing signs of wear.
    Jun 2016
    Regina, SK
    13
    Re: Very Noisy Pump
    Yes, it would have still been running with little water. I took the motor off and inspected the impeller, it turns freely with no debris. Motor is quite hot, is that normal? As I don't remember it being that hot.
    Can the bearing be replaced by itself? Is there a Hayward part for that alone? Instructions on replacing?
    Thanks
    Jun 2014
    15,130
    Re: Very Noisy Pump
    Yes, bearings can be replaced, but that's a slightly more detailed DIY-type job which might require some specialty tools if you're not already equipped to do so. Often times when a motor needs to be replaced, owners will simply un-bolt and remove the motor assembly from the pump basket. Replace a seal or two, perhaps the diverter/impeller if needed, reconnect the electric, and be on their way. You should be able to Google your motor model/part number for replacements. Or you can contact Inyopools.com for some part availability. They have quite an extensive product line when you get ready.
    Jun 2016
    Regina, SK
    13
    Re: Very Noisy Pump
    Thanks..with is being so hot, is it better to just replace the whole motor?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Re: Very Noisy Pump
    any chance it's a vibration causing the noise?
    Dolphin E10 Cleaning Robot.
    Jun 2016
    Regina, SK
    13
    Re: Very Noisy Pump
    How can you tell? We have had all the equipment installed for 3 years, now making the noise with no change. The equipment is in a shed, so no weather gets it.
    Thanks
    Jun 2016
    Martinez, CA
    207
    Re: Very Noisy Pump
    Bearings are pretty cheap ($10 ea) and heat may be coming from one bad bearing. Id probably go the bearing route first as a fairly easy repair (although as said above, not as simple as just replacing the motor). I had mine swapped out in 30 minutes and used a simple puller from harbor freight that cost $12.
    BTW had a similar issue on my 2 year old pump (just out of warranty). I also upgraded the bearings to sealed (not shielded) bearings and has been running fine for 7 years x 6 hrs a day.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    Jun 2016
    Regina, SK
    13
    Re: Very Noisy Pump
    Is the shaft seal the same as the bearing in these pumps? Or what part # would the pump be?
    Thanks
    Jun 2016
    Martinez, CA
    207
    Re: Very Noisy Pump
    If repairing or replacing motor, it's always a good idea to replace the mechanical seal while everything is apart. Sometimes a leaking seal is what actually caused the bearing failure due to water spraying into the motor and washing out the bearing grease. If so, changing out the motor won't actually fix the root of the problem and you will have a repeat failure down the road.
    There are some pretty good utube videos showing how to replace the bearings and even some on how to rebuild the pumps. If you aren't real famaliar with how to do this, this will better explain it and help you decide if this is something worth tackeling or not.
    BTW- shaft seal is the piece preventing water leaking around the pump shaft. Bearing is internal in the motor and requires the endbell of the motor to be removed to access it and make a repair.
