Results 1 to 17 of 17
Thread: Winterizing Questions - Can I Do This?
    May 2016
    MD
    195
    Seems easy enough...
    I think the part where it may make or break me is on the blowing the water out of the pipes... I got 2 in pool drains at the bottom... and then the 2 skimmers on opposite sides of the pool.
    Where do you stick the Wet Vac to blow it out? And where does the water go? Or since they are underground pipes is this not really an issue?
    I guess before i get to involved, this is the first part.
    I know they put antifreeze in the pump its self.
    And then there is the sand filter? leave water in it or does it drain out as well?
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    Jun 2014
    15,153
    Re: Already trying to figure out if i want to do this
    Planning ahead huh? Well, many folks actually disconnect their pump and take under cover in the garage or something. Yes, you remove the drain plug from the filter and let all the water out. But winterizing is unique to some pools and owners who have learned their own tricks and stuff that works best. Other swill reply, but before you got too overwhelmed, start by reading these threads below to get a good idea:
    Pool School - Closing an In Ground Pool
    Pool School - Closing (Winterizing) Your Above Ground Pool
    Winterizing, how do you protect the main center pool drain?
    Closing an in ground pool
    May 2016
    MD
    195
    Re: Winterizing Questions - Can I Do This?
    I have.. but i guess there was more to it than i found
    I have to schedule the pool company in the next month or so, which is why I need to see if I can pull it off.
    May 2016
    MD
    195
    Ok... so.. hmmm... I think I might have just figured it out... stick the vaccum in the skimmer hole? and wait for the water to blow through the whole system which includes the pump and then out the 1 inch return tube?
    I am one of those people who needs to see it done, and then can remember and do forever... I was never around when they have closed the pool the last 2 years for us, so who knows what they do...
    markuszoom5's Avatar
    Jul 2014
    Liverpool NY
    121
    No, first you drain the pool a bit. Maybe almost to the lower line of skimmer to allow for rain water room. You need to disconnect the pool pump if you can. Then find the valve that closes the main drain but isolates the skimmer. Screw the gizmo (a plastic thing) into the skimmer hole and leave the little gizmo plug off. Use Teflon tape around gizmo. That is where the water will shoot out of. Then you put the shop vac in the pipe where you disconnected the pool pump. You can use a wet rag or something to create a better deal. Then you blow out the water with shop vac. Pour pool anti freeze throug the gizmo home into skimmer line with a funnel. You will need about 2 gallons. Next you have to find a spot where you can disconnect a union for the outtake port after the filter so you can blow out the returns. Disconnect the pipe and put the shop vac into that pipe that returns the water to pool. Start blowing out the returns. Have another person plug the closer return then have them plug the far return. Then put antifreeze into that pipe where you just blew the returns out. Finally open the valve to the main drain pipe and blow them out as best as you can. It does not have to be perfect. Pour antifreeze. I live in Syracuse NY where temps go down to -20 sometimes. This I think is a freeze proof method. Had the pool for 3 years now. It's actually 13 years old. I don't think the pool store does such a thorough job.
    If your pump and no unions and is hard plumbed then obviously you poor antifreeze into it as you can't remove it. The goal is to get water out of skimmer line, returns, and main drains followed by antifreeze addition. That's all.
    May 2016
    MD
    195
    ok. wow. well. I need to take pictures... but I think the pump is hard locked on with sealant. so I can figure they just used anti freeze and never did the blowing out part. Quite sure they never un plugged the pump from the plumbing as it has always been outside. The pool company put it in... and probably not thinking about making it removable.
    Guess I need to figure what I can take off and what i can't... everything seems glued on, but maybe not... just scared to screw it all up.
    Jul 2014
    Liverpool NY
    121
    Quote Originally Posted by Puppiesonacid View Post
    Take pics of your pump, filter, and plumbing setup and let the Forum see it, so that we can help you. If your pump and filter are hard plumbed that is not a good thing in cold climates. You want to be able to remove the pump and drain the filter and blow out the lines. If things are all glued you can have a pool pro come out and put on some unions and flexible PVC so that you can disconnect things. They should not charge you more than $100-200. I would go two or more valves from the intake pipe depending on how many drains/skimmers you have. And flexible PVC tubing with a union on each side (pump - filter) so you can disconnect things in fall when you close. Look below and see how my setup is. I can disconnect the pump at the intake port, then at the output port and put it away. then I take off the flexible pipe from the filter and put it away. This way only the filter stays outside. If something happens to the multi port valve i don't care since it's only $100 or so. The line that goes away from the filter (dirty looking pipe) is the line you use to blow out returns. The other out that goes into the pump out of the ground is what you use to blow out the skimmer/main drain.
    Circa 20,000 gal IGP, 12 years old, Hayward SP2607X10, 1 hp single speed pump, Hayward S244T Sand filter, vinyl liner, using Aquacheck test strips and Taylor K-2006 Test Kit, 1 skimmer, 1 bottom drain, 2 jets (near stairs and on the opposite deep end)
    May 2016
    MD
    195
    Here are a few picts
    Jul 2014
    Liverpool NY
    121
    It looks like everything is hard plumbed. Then you will have to go through the pump intake port (one the vertical side of pump) to blow out the skimmer and then through the pump output port (the one on top)to blow out the returns and main drain followed by lots of antifreeze until the pump body fills with it. I think you will bed at least 6 gallons. It's cheap though. Why do people hard plumb pumps in northern climates? I don't get it.
    May 2016
    MD
    195
    Quote Originally Posted by markuszoom5 View Post
    thanks, and mo money if something breaks?
    May 2016
    MD
    195
    What kind of pole do you need to help stretch the cover over the pool? i know the guys who do it use some pole... is there a certain one? I have no idea what to call it or where to find one... and i have searched the internet and then some...
    Jul 2014
    Liverpool NY
    121
    It's a stainless steel rod that the ring goes around then you jam the ring in the peg in concrete and pull out the rod. It's really simple.
    May 2016
    MD
    195
    funny thing is my wife explained it to me how they did it cause she was home... Is there a name for it... or just go to a hardware store and get one? She said the pipe went in the cover strap hook thing, and they place it over the inground tie down, and it just pulls on... seems easy... just don't know what to call it.
    Jul 2012
    Waterloo, Ontario, Canada
    10
    It's called an Installation Rod. You can look up Safety cover installation rod, or look under safety cover accessories. Pool supply places or Amazon.
    21,000 gallons (81,000 litres) inground vinyl, 16 x 32, Hayward S-244T sand filter, Hayward 1 hp superpump - 2 speed, Hayward 250,000 BTU Nat Gas Heater
    May 2016
    MD
    195
    Thank you I tried every sort of word to find it and couldn't...
    Apr 2015
    South Central PA
    297
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,528
    Deleted
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
