Thread: is there a way to prevent chlorine smell at a pool party?
    Jul 2016
    Gainesville, FL
    126
    my CC level is zero now but I believe it will rise quickly once people get in.
    CYA: 60
    FC: 5.5
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: is there a way to prevent chlorine smell at a pool party?
    Bump your FC up to 9.5 before they get there
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Agree with Bruce and thats what I do when guest are coming over. (add about an hour before they arrive then test after they leave)
    That FC level of 5.5 is very close to your minimum of 5...I would make sure to add more bleach when it hits 6
    at all times to be on the safe side.
    Dolphin E10 Cleaning Robot.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,461
    Right, more bleach! My CYA is 80 and my FC is 8, before a party I add a jug of 8.25%which adds 4 ppm to the pool. Sometimes, I'll add two jugs if there are extra people, kids or we plan to swim all day and into the evening. More FC will oxidize CCs faster. And remember, it is safe to swim when FC is above minimum and up to shock level for your CYA, FC/CYA Chart. As soon as FC drops below minimum the kill rate for bacteria and pathogens is too slow to fully prevent person to person disease transmission, especially in kids. Bacteria colonies can double in size in an hour if they are not killed quickly enough.
    Mar 2016
    houston, tx
    9
    Quote Originally Posted by pooldv View Post
    Why is your CYA so high at 80? Wouldn't you want to drop it to 30-40 to save your FC?
    12,000 IG plaster with spa / Pentair IntellifFo variable speed pump / Hayward Cartridge Filter.
    DFW, TX
    24,461
    Saltwater pool is recommended at 70-80. CYA protects FC from the sun and lowers daily FC burn. So, the more CYA the less your daily FC loss. In Houston you will want to be at 50.
