Thread: pH issue.
    Dec 2015
    Canandaigua/NY
    2
    pH issue.
    Hello,
    Here is my issue. My clear pool had a pH of 7.2. I wanted it to be around 7.4. So I added pH plus and achieved my desired result, 7.4. This however makes the pool very cloudy. I can clear the pool water quickly by adding pH minus but then the pH is back to 7.2.
    My chlorine is at 3, Alk is about 100.
    Any ideas?
    Thanks!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: pH issue.
    Welcomemto the forum!
    Im guessing its the product you used, because a move from 7.2-7.4 shouldnt be enough to cause a precipitation reaction. Theres generally nothing wrong with a 7.2 and most pools have a tendency toward a natural pH rise. I would suggest letting the pH come up on its own naturally, and worry about it if it needs to be lowered in the future.
    Essential Links:
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: pH issue.
    You can speed up the ph rise by aeration as well. Turning return to break the waters surface, kids splashing around, water features etc... Creating bubbles will raise PH..
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Dec 2015
    Canandaigua/NY
    2
    Re: pH issue.
    Thanks.
