Thread: Cleaning inside skimmer
    May 2015
    TN
    312
    My skimmer on the deep end is so nasty on the inside of it. It grosses me out thinking that stuff is recirculating in my pool. Is their anyway to clean it up besides draining my water below the skimmer?
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    pookiesunshine's Avatar
    May 2016
    Cincinnati, OH
    435
    Re: Cleaning inside skimmer
    magic eraser works pretty well except for deep crevices.
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
    JoyfulNoise's Avatar
    May 2015
    13,262
    Quote Originally Posted by lindz18 View Post
    Why is it gross? Is it full of debris?
    As others have suggested, dark discoloration of the plastic is mostly surface "crud" that is easily removed with a Magic Eraser sponge.
    If your skimmer gets lots of debris, then perhaps you should use these in the skimmer basket -
    Disposable Hair Net, Spun-Bonded Polypropylene, White, 100 per Bag: Science Lab Hairnets: Amazon.com: Industrial Scientific
    They fit over the skimmer basket and they are very good at catching debris. They are disposable and so you just pull them out and throw them away, no need to empty and clean the basket.
    Is their something in there particularly troubling that is hard to clean out?
    Matt
    May 2015
    TN
    312
    It looks black. I assume sediment and just stained
    May 2015
    13,262
    Definitely try a Magic Eraser
    Matt
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Just ME'd my black skimmers this week. Sparkly now.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
